Can single UART send data to multiple device
12 posts / 0 new
Hi
I have question Can single UART send data to multiple devices?. I don't think because Uart can't identify the device
Total votes: 2
Yes, of course it can - as your diagram shows!
The limitation, of course, is that every single device will receive exactly the same stuff!
If that's not what you want, then you will need to add some scheme so that the PC can tell what's intended for it - and ignore other stuff.
ie, you devise some sort of protocol which has some provision for addressing the receivers.
EDIT
The addressing can be done without requiring any extra or special hardware at all - it can be all purely in "software" using the standard UART comms
The bigger problem is when you want all the PCs to be able to send stuff to one UART on the microcontroller - because you must not just short multiple transmitters (ie, outputs) together!
An example of where that is very useful:  https://www.avrfreaks.net/comment/2306116#comment-2306116
But that's what MPCM and the 9th bit is all about ?!? The result is not entirely dissimilar to what is achieved in I2C addressing, though rather than a separate TWAR the slaves simply have to read the other 8 bits when bit 9 is set and compare against their assigned address to decide whether to filter.
Yes, it is.
Specifically, it is one way to address:
although PC's don't (directly) support it - so probably not the best choice where PCs are specifically targetted.
Indeed
EDIT
Recent thread on the MPCM stuff:  https://www.avrfreaks.net/forum/mpcm-mode-send-data-slave-master
EDIT 2
that thread also has a reference to a protocol - "SNAP" -  which gives you addressing without requiring MPCM: https://www.avrfreaks.net/commen...
As I pointed out in another thread, S.N.A.P is a protocol designed for just such a case, here are the links: https://www.avrfreaks.net/commen...
Indeed - that was my reference in EDIT 2 of #3
laugh
Just encode an identifier in all of the commands you send out:
U5RPM100    ... unit 5 set RPM to 100
U9RPM100    ... unit 9 set RPM to 234
U8LEDA1      ... unit 8 turn LED A ON
U8LEDE0      ... unit 8 turn LED E OFF
You can then use a terminal to send them.  As mentioned, the response is limited to 1 unit at a time.
You're thinking of the other thread?
Standard PC COM ports don't (generally) have "bussable" outputs
I'm assuming the hardware for the slaves will support tristating of their tx lines.  If the slaves are truly PC's (the op shows that, though it may be generic), the PC needs some hardware anyhow, since it prob doesn't have a serial port in the first place.
Or perhaps, the comm is only one-way only, from the master unit.  I wish PC's still had serial ports...quite often add a lot of malarky to get them back...why not just include in the first place... a money $$$ maker fro the adapter guys.
Soon PC's will get rid of USB ports and instead have XVG3 (eXtended Virtual/Generation 3) ports.  You'll be able to buy adapter hubs & cables to convert from XVG3 to USB.
IF that bus-connection is at the RS232 level rather than raw UART level, then you have to be aware that every (conforming to standard) RS232 receiver has a several KOhm resistance to ground. That makes it really hard to parallel inputs. There is no problem if the outputs and inputs are "raw UART" (also known as "TTL").
JIm
