CRC and ATECC608A-SSHDA
3 posts / 0 new
  Hi there
  I am trying to figure out how ATECC608A handles the CRC. I do not have yet datasheet for ATECC608A-SSHDA, I do have for ATECC508A and ATECC608A-TNGTLS. Both these two datasheets describe the same functionality regarding CRC.
  I started to test with the simplest command, Info. For start, I built the I2C packet and for CRC I did calculated with online calculator just to test. It did not work. Out of solution, I made a loop and tested all 65536 possible values. After about 21 minutes I got a match. However, I cant' get any online calculators to get the same value. When the CRC is correct, it replies with data requested. Here is what it works:
send command:
receive from ATECC608A - last two bytes are CRC
  I did try online calculators:
https://www.lammertbies.nl/comm/...
https://crccalc.com/
  What could be the problem ?
  Thank you.
Well for one, its not a CRC!  But further discussion of crypto on an open forum may be prohibited!   cheeky
Forum for Atmel's security products / topics:
https://community.atmel.com/forums/general-security-discussions
