Circuit breaker switch extender
6 posts / 0 new
Hi, i am looking for small metal rod that extends switch on the circuit breaker and i dont know how is it called in English.  I marked exactly what i mean on the attached picture.
Thanks in advance :D
You'd make it a lot easier if you put the picture in the post - where we can see it:
See Tip #1 in my signature.
It would also be helpful to give a manufacturer's part number & link for that - so that people could look it up.
Then we may be able to spot what they call it.
I would think that "link" or "ganging" would be good keywords to try.
The part is going to have to be specific to the particular circuit breaker - so have you contacted the manufacturer to ask them?
EDIT
You could also try a google image search...
Ok, thank you for info and tip on proper image posting.
So how about the rest - part number, link, etc ?
Total votes: 2
That piece will be very specific to that manufacturer. And, maybe even to that model breaker.
About the only way you will find another is from someplace that sells those breakers OR from the manufacturer, itself.
Yes, i contact manufacturer and they gave me part number of that metal link thing. And yes, it is specific to this particular model of circuit breaker.
