Problem programming Arduino UNO in Atmel Studio 7
6 posts / 0 new
I'm trying to use my Arduino UNO as a regular ATmega328p uC. So I installed the lattest version of Arduino IDE to be able to configure my Arduino Uno as an external tool.
For the external tool I used these routes:
Command: C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude.exe
Arguments: -C"C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:"$(ProjectDir)Debug\$(TarjetName).hex":i
I have already verified the folder and the .hex file does exist, and the AVRdude is able to detect and read the Arduino because in the Output window I get this:
avrdude.exe: Version 6.3-20190619
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
             Using Port                    : COM4
             Using Programmer              : arduino
             Overriding Baud Rate          : 115200
             AVR Part                      : ATmega328P
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : Arduino
             Description     : Arduino
             Hardware Version: 3
             Firmware Version: 4.4
             Vtarget         : 0.3 V
             Varef           : 0.3 V
             Oscillator      : 28.800 kHz
             SCK period      : 3.3 us
avrdude.exe: AVR device initialized and ready to accept instructions
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe: safemode: lfuse reads as 0
avrdude.exe: safemode: hfuse reads as 0
avrdude.exe: safemode: efuse reads as 0
avrdude.exe: reading input file "C:\Users\Public\Atmel\GccApplication1\GccApplication1\Debug\.hex"
avrdude.exe: can't open input file C:\Users\Public\Atmel\GccApplication1\GccApplication1\Debug\.hex: No such file or directory
avrdude.exe: read from file 'C:\Users\Public\Atmel\GccApplication1\GccApplication1\Debug\.hex' failed
avrdude.exe: safemode: Fuses OK (E:00, H:00, L:00)
avrdude.exe done.  Thank you.
The real problem comes here:
And in the device name:
...Debug\.hex: No such file or directory
Because it doesn't get the right name of the .hex file, it just search for one "noname".hex file
I tried to modify the param $(ProjectDir)Debug\$(TarjetName).hex
with (ProjectName) because the .hex file has the same name than the project.
also tried $GccApplication1.hex (the current file name and nothing).
So I think the could be another parameter that could replace (TarjetName).hex
Here is the simple code I'm trying to run:
 * GccApplication1.c
 * Created: 05/04/2020 07:56:35 p. m.
 * Author : Abraham Macías
	DDRB |= (1<<DDB5);
    while (1)
		PORTB |= (1<<PORTB5);
And here is the route and files in the folder:
Atmel Studio 7:
My Arguments are:
-carduino -Pcom55 -pm328p -Uflash:w:$(TargetName).hex:i
And Initial Directory is:
$(TargetDir)
Your Tool is finding the avrdude.conf file successfully.   I assume the COM4 suits your PC.
But you have a convoluted (but correct) way of specifying the HEX file:
The problem is:
i.e. it does not expand $(TargetName) correctly.
You appear to come from Ireland.   So I would expect $(TargetName) to be spelled with a g and not with a j
Note that you should make sure that your project is selected in the Solution Explorer for the macros to expand properly.
WOW!!!! Indeed that was the problem!!! Thanks soo much!!! Solved!!!
Just a tip for the future but you should never need to (mis)type things like $(TargetName) anyway. When you are editing commands like this note the arrow at the end of the "Arguments" line:
If you select "Target Name" off this list it auto inserts:
So I never had to type any of that.
What nationality is this ?
The screenshots show directories in Spanish.    I just assumed that Tarjet was a valid word in another language.
Google suggests "target" is objetivo
That's Cliff's point (I think)  - by using the menu selections, you cannot possibly select something that isn't valid in Atmel Studio's language.
