GCC Toolchain Change Logs
12 posts / 0 new
I need to see what changed between GCC Toolchain 3.6.0 and 3.6.2
So far Google and forum searches have not yielded anything helpful.
Where can I find the appropriate changelogs for GCC AVR 8-bit?
Chuck Hackett
A first step would be finding out the versions of the compiler(s). It's definitely not v3.x what you are using.
If you are talking about Atmel/Micochip "toolchain" version numbers they have no relation to the avr-gcc and binutils (and AVR-LibC) version numbers so try running the tools with -v to get their version numbers then check the bugzilla for changes between one tagged release and the other of each component.
See my post #3 in this thread:  https://www.avrfreaks.net/comment/2885271#comment-2885271
The two versions I am dealing with are ( as identified by the release notes PDF in the respective avr8\avr8-gnu-toolchain folder) :
3.5.4.1709 (I had the 3.6.0 above wrong) - compiles my STL template references correctly
3.6.2.1778 (came with Atmel Studio 7.0.2397) - does not compile my STL template references correctly, error:
default argument for template parameter for class enclosing 'class std::basic_istream<charT, traits>::sentry'
which is why I am trying to see the changes between versions.
running avr-cpp -v yields (among other things):
gcc version 5.4.0 (AVR_8_bit_GNU_Toolchain_3.6.2_1778)
Which matches the avr-gcc version number above.
I am looking for changelogs for avr-gcc, not gcc because I assume that the avr-gcc logs might include items in addition to the gcc changes (which I assume they would include by reference)
Never used/seen bugzilla but checked with google and just found open "bugs" but, at the moment, I am assuming that this is due to some feature change, more stringent checks, etc., not a "bug" ...
I found this page that seems to reference change logs but I can't make sense of it:
https://launchpad.net/ubuntu/+source/gcc-avr/+changelog
STL? avr-g++ does not have STL??
3-rd party STL library that works under toolset  3.5.4.1709  but not toolset  3.6.2.1778 and I am trying to find out what changed in the toolset to cause this.
See:  https://www.avrfreaks.net/comment/2885271#comment-2885271
Shouldn't you be asking the tool vendor?
I guess this STL is related to OpenWrt and BusyBox.
https://uclibc.org/
Would that be expected to work with the AVR toolchain?
Just download the version that works, I assume 3.5.4 will be the one you had before (which seems to be gcc 4.9.2 instead of the 'current' 5.4.0)-
https://www.microchip.com/mplab/avr-support/avr-and-sam-downloads-archive
or, you can probably fix the problem-
https://godbolt.org/z/cnWdPS
(probably would only be the tip of an iceberg)
I don't know the c++ differences between gcc 4.9.2 vs 5.4.0, but it looks like template parameters were previously tolerant of providing default parameters at a point after a declaration was already made. I'm not a c++ expert either, and have not been in any hotel, much less a HI express, in a long time.
edit-
Probably a good start-
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=53856#c4
but you can also come up with more that relate to c++ default parameters, so I can see how that could have changed somewhere from 4.9.2 to 5.4.0, where they previously allowed something that was not according to 'rules'. You could also check if the c++ library has a newer version available that conforms to later versions of the compiler, or simply just use the old compiler version.
 You probably need to compare the gcc-version rather than the "toolchain version."   Toolchain 3.6.2_1778 has avr-gcc 5.4, and Toolchain 3.5.4.1709 has avr-gcc 4.9.2
Behavior of C++ templates is VERY unlikely to be caused by Atmel-specific changes for AVRs, so you'd need to check out the changes between the core gcc 4.9.2 and 5.4.
Probably not anything beyond "started with gcc 5.4..."  Vendor versions are usually "standard release XXX plus these patches."  I don't think they expose the whole RCS tree, even if it uses an advanced enough RCS to track "parent branch" changes.
(although first, I'd check with some C++ experts to see if the code you're using is correct as-is, or whether the new version is making a valid complaint and should be fixed.  Alas, writing portable/compatible template libraries is pretty rarified territory.)
If you aren't explicitly setting the language standard used (e.g. -std=c++11), it is possible that the default language standard changed resulting in the behavior you are seeing. I wasn't able to quickly find what the default language standards are for various versions, but you should be able to check as documented here: https://stackoverflow.com/a/27980787. That same stackoverflow answer also mentions an issue with template aliases when gcc is used instead of g++.
build-avr-gcc: avr-gcc build script
toolchain-avr-gcc: CMake toolchain for cross compiling for the AVR family of microcontrollers
avr-libcpp: C++ standard library partial implementation (C++17 only) for use with avr-gcc/avr-libc
picolibrary: C++ microcontroller driver/utility library targeted for use with resource constrained microcontrollers
picolibrary-microchip-megaavr: picolibrary HIL for megaAVR microcontrollers
picolibrary-microchip-megaavr0: picolibrary HIL for megaAVR 0-series microcontrollers
