duplicate number
64 posts / 0 new
Hi
I want to find duplicate number in array I have tried on paper by making flow diagram
Here is my approach to solve the problem
I believe I can find only one duplicate number that is 3 and my approach failed when there are more then two duplicate numbers in array
any suggestion would be appreciated
You have to do multiple passes.
I don't understand your flowchart!
What is this for:
What does it mean?
Think about how you do this manually: For each element in the array, you need to look at every other element to see if it has the same value.
So you need 2 indexes (indices?):
  1. The element you're considering;
  2. The the "other" elements.
HINT
You only ever need to scan forward from the element you're currently considering ...
Actually, you need to clarify that.
Do you just need to identify that there is any duplicate ?
Do you need to count how many duplicates ?
Do you need to list all the duplicated values ?
Or what ?!
A key part of software development is getting the specification clear, correct, and complete!
Do I need to use two FOR loop
You need to think about the design before getting bogged down with implementation details like that!
Think about what you need to do.
This is where the flowchart comes in.
Only when you've got that do you need to worry about how to do it.
EDIT
Usually, the how will become obvious from the what.
There is not necessarily going to be just one way to implement the design; ie, there could be multiple possible hows to do your what.
What is this for:
What does it mean?
HINT
I am assuming first number of array is duplicate
Or what ?!
Yes first I want find all duplicate numbers in array and then then want to count how many duplicates
Seems to me the solution would be something like:
#define N 7
uint8_t digits[N] = { 3, 5, 4, 2, 3, 1, 5 };
int main(void) {
    uint8_t test;
    for (int i = 0; i < N; i++) {
        test = digits[i];
        for (int j = i + 1; j < N; j++) {
            if (digits[j] == test) {
                printf("element %d with value %d is duplicated at element %d\n", i, test, j);
When I build and run that I get:
You should know how to do quoting by now.
Reminder: https://www.avrfreaks.net/forum/...
So you'll need a way to store multiple values - won't you?
As always, take it one step at a time!
But counting them is trivial once you've found them.
Indeed.
That saves him having to think or work it out.
But you are just using a "Magic Number" of 3.
So you are also assuming that the first element of the array is 3.
So this won't work for any other array which doesn't have 3 in its first element!
clawson wrote:
#define N 7
int main(void) {
    uint8_t test;
        test = digits[i];
3 and 5 are the only duplicate numbers in given array your solution doesn't seems to correct
#include <stdio.h>
#define N 7
int digits[N] = { 3, 5, 4, 2, 3, 1, 5 };
int main(void) {
    int test;
        test = digits[i];
    return 0;
Result
$gcc -o main *.c
$main
element 0 with value 3 is duplicated at element 4
element 1 with value 5 is duplicated at element 6
I have shown my best attempt to solve problem and trying best
this code find duplicate of first number in array
#include <stdio.h>
#define N 7
       if (digits[0] == 3 )
           printf("duplicate number found : %d \n", digits[i]);
           break;
         printf("duplicate number not  found \n");
         break;
    return 0;
$gcc -o main *.c
$main
duplicate number found : 3
Yes it is - look again at the results it prints!
Well, that was you're first attempt.
Just trying to explain to you how to approach this so that you know how to do it yourself - rather than just giving a solution.
No, it doesn't.
It just checks if element 0 of the array is 3.
If it finds that element 0 of the array is 3, it reports that as a duplicate - irrespective of whether 3 is actually duplicated in the array or not!
Again, don't jump straight to code - think about what to do first before trying to code how to do it.
EDIT
Build & Run your code again, but with this data in the array:
int digits[N] = { 3, 5, 4, 2, 0, 9, 8 };
Your code will still report a duplicate - even though no values are repeated in that data!
Eh? My solution worked perfectly. The result was:
That is exactly the case in:
element 0 with value 3 is duplicated at element 4. that is:
There is no question about this. Element 0 is most definitely duplicated by element 4. Also
element 1 is duplicated with element 6. Both my output showed this and yours:
$gcc -o main *.c
$main
Both those say EXACTLY what I just explained so in what sense is this "doesn't seem to correct".
I can only assume you are seeing something I'm not seeing or you don't understand ?
I think he may be confusing the element number (index) with the value stored at that position in the array ?
We're all programmers here. I thought it was kind of a basic fundamental that all programmers know what "element" and "value" mean ??
okay so first trying to fix in flow chart
Does it make any sense ? i will look help to fix flow chart first
after last box test = 5, I do not understand what to do I am planning to use another loop. I have limited version that's why didn't make next loop
No.
You are still just using 3 as a magic number:
As explained, and as illustrated by clawson, you need to bre reading from the array.
Then looking again in the array to see if what you read is repeated.
Eh??
EDIT
fix quote
I understand array index and value
array index are digits[0], digits[1], digits[2], digits[3], digits[4], digits[5], digits[6],
array values are 3, 5, 4, 2, 0, 9, 8
Maybe the problem is when you have more than 2 copies of a number, for example:
#include <stdio.h>
#define N 8
int digits[N] = { 3, 5, 4, 2, 3, 1, 5, 5 };
int main(void) {
    int test;
        test = digits[i];
    return 0;
Outputs:
element 1 with value 5 is duplicated at element 7
element 6 with value 5 is duplicated at element 7
In this situation some way to keep track of already tested duplicates would be needed.
Ha ha - that takes us back to #4 and a clear definition of what the problem actually is!
But (s)he really needs to get the basic problem sorted before adding more complications!
So how can you possibly say that clawson's code in #8 is not giving the correct answer??!
Baffled!
array index are digits[0], digits[1], digits[2], ...
The indexes are just the highlighted numbers - 0, 1, 2, ... !
Index = element number. It's the same thing. The array in my example has 7 elements numbered [0] to [6]
Actually - No - One pass should be sufficient, but you do need a container to store the number of occurrences of each integer.
If your set of numbers is only 0 .. 9 (or even some other low value) then that container becomes trivial.
I'd write some demonstration code but I've got other things to look at this evening.
This is a terrible approach.   FIRST, in at least 3 or four COMPLETE SENTENCES, state what your trying to accomplish.
Do not even try to think of the solution if you can't state what you are trying to do!
"I want to find duplicate number in array" I have tried on paper by making flow diagram
This essentially says...Next to NOTHING useful are you seriously lacking all details?...try again!!!
"I want to buy a car but have a problem"  ...that is what you are stating...no useful details
Problem statement
1. I want to identify that there is any duplicate ?
2. I want to count how many duplicates ?
3.  I want to list all the duplicated values ?
post #19 look at flow chart that is my attempt but Its not correct so I am looking help to fix flow chart first. It would appreciated  if any one can help to fix flow chart first
is this a school assignment?
to me this is a big throwback in to the time I went to college. we had to do the exact same thing.
I have seen more exercises that I identify with having had a school.
You still haven't explained what you want....What do you mean by identify?  What do you mean by duplicate?  Are 3 of the same item counted as 3 duplicates, or does each item have to be duplicated with one of its own clone?
So if you have 33  33  22  33  44  22   ....are you saying you have 5 duplicates, or maybe 2 duplicates?   Almost all of the values are duplicates of something, so here is your list:  (I want to list all the duplicated values ):    33  33  22  33  22
...or do you simply want 22, 33 ??
sky33 wrote:
Problem statement
No, that is not a problem statement!
That is just a copy & paste of my questions to you in #4 where I was asking you to properly define the requirement!
See also #22 and #23 - where further ambiguities were pointed out
And now #30 has highlighted some more things that you need to clarify.
These are really things that should come out in your analysis & design phase - long before you get into coding!
All of the posts after that are doing exactly that!
It's not about fixing a broken flowchart - it's about understanding the question first!
You need to go right back to basics, and think about how you would do this manually - with paper & pencil.
Forget all about flowcharts, computers, arrays - just think how you'd do this with a list of numbers on a piece of paper:
  1. First, you write down the list
  2. Then you consider the first entry in the list
  3. Then you look at each of the following entries, asking your self, "is this a duplicate?"
    (whether you need to carry on past the 1st repetition depends on how you define the problem)
  4. Now you go back to the second entry in the list
  5. Again, you look at each of the following entries, asking your self, "is this a duplicate?"
    (you don't need to look at the preceding entries, because you've already looked at them in the previous step)
  6. and so on - until you've done the whole list.
Now you can start thinking about how to implement that - a flowchart could be your next step ...
EDIT
Pencil & paper is also a very good way to test your flowchart & your code!
You go through each step of the code, or box of the flowchart - manually doing what it says, and noting what's happening.
Have you done that with your flowcharts - to see where they go wrong ?
Have you done that with clawson's code - to see how it gets it right ?
For example, as an implementation you might sort your values in numerical order by some scheme...then the sorted list makes finding "duplicates" easier...perhaps faster..perhaps slower overall (takes time to sort).  For example a bubble sort or linked list method
However, any of this comes AFTER you have clearly defined the problem & what you want to get out of it.  You must consider all cases so your needs are thoroughly described to cover all possibilities.
Problem statement
OK so the way I would do this kind of depends on the point
If it is just the digits 0..9 then there's no problem having something like:
uint8_t count[10];
#define N 7
int main(void) {
        count[digits[i]]++;
    for (int i = 0; i < 10; i++) {
        if (count[i] > 1) {
            printf("value %d is duplicated %d times as items", i, count[i]);
            for (int j = 0; j < N; j++) {
                if (digits[j] == i) {
                    printf(" %d", j);
            printf("\n");
this outputs:
value 3 is duplicated 2 times as items 0 4
value 5 is duplicated 2 times as items 1 6
But if the data isn't just the digits 0..9 then you can't really keep a count[] array to cater for all positive integers that may occur so in this case I would suggest a linked list that grows dynamically for each duplicate found and something like:
typedef struct _count {
    uint8_t value;
    uint8_t count;
    struct _count * next;
} count_t;
(the types may need to change if you want to cater for values or counts above 255).
Way over the top for this question... but I recently had to evolve a mechanism to do a similar task, but with a much more complex data structure, looking to see whether duplicates existed, and if they did, whether other parts of the data were also duplicated - so  duplicates were acceptable, but only if every element in the structure was also a duplicate. It was a large structure which had to be parsed from a file of several megabytes of text... the data I had to parse was naturally not ordered.
This ended up as a multi-stage process.
1) for each line of text, parse it into a structure; walk a doubly linked list until I found a link with a higher value that the one I just parsed, and insert the new structure before that link. That gave me an ordered list, at the cost of having to walk an average of half the list for each new entry.
2) Now I have a nicely ordered list, start walking from the front and for each entry, see whether the previous link has the same numeric value; if so, copy a variable 'count' (initially zero) to the current link and increment it. Then zero the count for the previous link. Just one pass.
After this I have an ordered list, each entry of which has a count entry of either zero, or the number of matching entries. It's only a courtesy detail that the initial file is generated in China, and that because of contact issues, isn't necessarily even real ascii; it has holes and strange characters and all sorts of other rubbish that I have to handle when I parse it. And there's an awful lot of malloced memory to clean up afterwards :)
As I said, possibly a little overkill for the task at hand...
Neil
Give a kid a bowl of Smarties and ask them to count the red ones, then the blue ones etc. the problem will get solved swiftly. Be it numbers or smarties, same problem.
more likely, the problem will get eaten swiftly!
laugh
avrcandies wrote:
  What do you mean by duplicate?  Are 3 of the same item counted as 3 duplicates, or does each item have to be duplicated with one of its own clone?[/quote
3, 5, 4, 2, 3, 9, 8, 5
same item will counted as duplicated
I simply want 22, 33
So, in other words, you want anything that occurs more than once?
Or anything that is non-unique.
This is a common problem with natural language specifications (ie, specifications in the languages people speak to each other).
When people speak to each other in natural languages, they tend to use words quite loosely; eg "duplicate" to mean "any repetition"  - rather than its precise meaning of "occurs exactly twice".
This is compounded when people are using a foreign language.
So the first step in defining the task is to get rid of all these ambiguities - sometimes called disambiguation.
So we are still waiting for you to give a complete & precise definition of your task.
If you can't give a complete & precise definition of your task, you cannot possibly write a 'C' program to solve it!
And it makes it very hard for people to help you - because we don't know what you are actually trying to achieve!
In what way wasn't #28 complete? Dunno about anyone else but it seems pretty clear to me what he wants.
If I could be arsed I might have a crack at a linked list version.
See #31 !
EDIT
Also #38 & #39 - "duplicate" is ambiguous.
Do we have different grasps of the English language then? Duplicate for me means something repeated, that is something that occurs more than once. Is there a question about that interpretation then??
I explained that in #39, and  avrcandies made a similar point in #30
Well at least Google and I agree...
"or more" means it doesn't have to be just TWO but any number of two or more.
duplicate is being used here as a noun not an adjective surely ?
Although I may tend to agree that we've got a bit distracted with semantics, this thread is a clear demonstration of how this step can be a difficult one.
To the OP:  don't be discouraged.  The core point is still important:  You must describe the problem with sufficient clarity before you can begin to solve the problem.  Here, 'solve' means 'design', or in your case 'flowchart'.  Whereas 'write code' is the last step: implementation.
Indeed.
I am really sorry if I couldn't  explain problem statement because english is not my first language. This is not homework assignment. I want to be a good programmer that's why I am making problem statement myself and trying to convert it into code. so I started to make flow chart and practicing with  paper and pencil
So go on - make you problem statement now.
i intended to write some C code to illustrate my #26; but because I think the OP would learn more by writing his own code, I thought perhaps not.
Instead I wondered how this might be solved in a higher level language. So here's a python implementation: Yep just a single line.
digits = [2,5,4,2,3,1,5]
duplicates = [digit for digit in set(digits) if digits.count(digit) > 1]
print (duplicates)
It works by creating a set of the numbers in the initial list These are unique with duplicates removed.
This set is iterated over and if the occurrence count of the number within the initial list is greater than 1 (i.e. is duplicated) that number is added to an output list named duplicates.
Finally the list of duplicates is printed.
nigel@E6420:~/Project/tmp /usr/bin/python3 /home/nigel/Project/tmp/duplicates.py
[2, 5]
And people say C is incomprehensible? That's going to confuse the OP even more...
Neil (who is usually fine with Python, at least when it's simple syntax and not done at all in a 'pythonic' way)
The joy of Python is that things like lists will grow dynamically (same true of vectors and other std:: data structures in C++ I guess?) but if OP is attempting C this brings me back to an earlier comment about probably needing some kind of dynamically growing data structure like linked lists in C.
clawson wrote:
...probably needing some kind of dynamically growing data structure...
I guess the OP needs to tell us three things...
1) What is the maximum size of the input array and
2) What size elements does the array hold?
3) How many different values can the things being counted take?
EDIT
added third thing to fully describe the problem
I think the OP needs to get the basics done fist before moving on to advanced stuff!
ie, just "is the number repeated?" to start with.
Which is what clawson showed early on.
I want to make program to find maximum time repeated number in array
for example  Digits = [ 2, 3, 9, 4, 2, 9, 5, 1, 1, 3, 1, -2, 5, 1]
Result should be
2 repeats two times
3 repeats two times
9 repeats two times
4 repeats only once
5 repeats two times
1 repeats four times
-2 repeats only once
1 is number that repeats maximum  time
So this is a different question from your first post!
Your new task requires two steps:
  1. Count the number of times each distinct value appears
  2. Find the highest count.
So you are going to need an array to keep your counts in. That array will also have to hold the value that's being counted.
If you're working on a given input array, then you know the size of that array.
The maximum number of distinct values that can appear in the "counts" array is equal to the size of the input array.
So you need to go through each element of the input array, asking, "is this a new value?"
  • If it is a new value, enter it in the next free element of the "counts" array, and set its count to 1
  • If it is not a new value - ie, it's been seen before - then you increment the count for that value.
EDIT
Some clarifications of "input" vs "counts" array
Hi awneil
I am not talking about source code and flow chart now  because I do not understand how to solve manually How do you solve this manually by hand for program flow
Good point.
So, manually, you have a list of numbers - that's your 'input' list.
You will create a list of values, with a count for each distinct value found in the 'input' list - that's your 'counts' list.
The 'counts' list will be no longer than the 'input' list'.
So you need to go through  the 'input' list, asking, "is this a new value?"
  • If it is a new value, enter it in the 'counts' list, with a count of 1
  • If it is not a new value - ie, it's been seen before - then you increment the count for that existing value in the 'counts' list.
1. start at the first digit
2. write that digit down
3. go through the remaining digits and look for the value you wrote down. Keep a count.
4. go to the next digit.
5. is it the same as you've written down previously?
6. if not, goto step 2
7. if yes,goto step 4
I've not added the logic to determine the end.
#include <windows.h>
#include <stdio.h>
#include <stdint.h>
int8_t digits[] = { 2, 3, 9, 4, 2, 9, 5, 7, 1, 1, 14, 3, 1, -2, 5, 1 };
#define NUM_ELEMENTS(x) (sizeof(x) / sizeof(x[0]))
typedef struct count_ {
    int8_t val;
    uint8_t count;
    struct count_ * next;
} count_t;
count_t * count_list = NULL;
count_t * create_entry(int8_t val) {
    count_t * pCount;
    pCount = (count_t *)malloc(sizeof(count_t));
    pCount->val = val;
    pCount->count = 1;
    pCount->next = NULL;
    return pCount;
void increase_count(int8_t val) {
    count_t * pCount = count_list;
    if (count_list == NULL) {
        // nothing in the list yet so no point searching - just create the first entry
        count_list = create_entry(val);
    else {
        while (1) {
            if (val == pCount->val) {
                // we've already seen this value so just increase the count
                pCount->count++;
                break;;
            if (pCount->next != NULL) {
                // walk the list
                pCount = pCount->next;
            else {
                // add new element to end of list
                pCount->next = create_entry(val);
                break;
int main(void) {
    for (int i = 0; i < NUM_ELEMENTS(digits); i++) {
        increase_count(digits[i]);
    // now gonna walk the list again printing the results..
    while (pCount) {
        if (pCount->count == 1) {
            printf("%d occurs once\n", pCount->val);
        else {
            printf("%d repeats %d times\n", pCount->val, pCount->count);
Have fun exploring the linked list in this !!
(BTW I doctored the data to have some more "single" values occurring just once).
PS:
Yup, that's an almost perfect description of what I implemented. ;-)
(if I was being efficient I should show how much easier this would be in C++ !)
step 1 Digits = [ 2, 3, 9, 4, 2, 9, 5, 1, 1, 3, 1, -2, 5, 1]
step 2 : 2
step 3 : 1
step 4 : 3
step 5 : no
step 6 : go to step 2
step 2 : 3
step 3 : 2
step 4 : 9
step 5 : no
...... and so on
Is it that you suggested ?
Something like this:
So you end up with your list of counts at the right-hand side:
Value 2 was counted 2 times;
Value 3 was counted 1 time;
Value 9 was counted 1 time;
Value 4 was counted 1 time.
The way my entire program works is basically this:
(the rest is just about printing the results). So that is just walking the array:
and passing each digit in turn (2, 3, 9 etc) into my "counting database":
For the very first number encountered (the very first 2) the code does nothing but create a new entry and set val=2 and count = 1then make sure count_list points to this one entry.
From then on the same thing happens every time. a number (and the next is 3) is passed to the list. The code "walks" the list looking to see if that "val" has already occurred. If it has it just increases the count on the existing entry then stops. If it has not occurred already (the searching process reaches the NULL at the end of the list without having found anything yet) then it create a new entry, sets the "val" within it and sets count=1 (and next=NULL) then adds this new entry onto the "next" pointer at the current end of the list.
And that's all that is really required. By the end of the input every number pushed in has either increased the occurrence count of some existing entry or it has caused a new node in the linked list to be created and recorded the newly found value there.
Finally the code in main just goes back to the start (count_list) and walks along all the "next" pointers until it hits the final NULL. For each node it just prints the value and the repetition count with special handling ("once") for those where the count is just 1.
And that's all it takes.
