please help - brushed motor with speed and direction control
35 posts / 0 new
Hi everybody,
I'm not an experienced tech guy but I have some knowledge about electronics and I come to you trying to get some help on fixing a nail polish machine that my wife managed to fried it by plug in the DC adaptor (12v) into the pedal socket. I tried to get some help from the manufacturer (or seller) but without success so I have tried to do some "reverse-engineering" by drawing the schematic of the circuit (attached). In fact, the circuit is controlling the speed and direction of a brushed DC motor (with a speed of up to 30k rpm).
I have identified then most of the parts with the exception of the 14pins IC which I think is the controller. There is nothing written on it but based on pin connections it looks like a tinyavr.
Can anybody help me with a solution to fix this?
Thank you very much,
Florin
Just started to learn!
Presumably putting too many volts on the pedal socket has blown up the microcontroller.
Looks like it is, at least in principle, possible to replace with attiny1614 (power pins in the right place) but you may be on your own with the firmware. I would imagine it reads the adc input (for the pedal) and varies the PWM duty cycle accordingly - not a difficult firmware.
Are all the power lines good? Is the voltage regulator ok?
If the updi is unlocked, you might be able to read out the old firmware, but only if the device isn't completely blown up (e.g. only one gpio port is gone)
hi @markxr,
Thank you very much for your fast reply (I was not expecting this since this is my first post here). This means that AVRFREAKS is really an active community :)
Everythings else is working fine, I mean the power line, voltage regulator etc. Thank you very much for your input, I shall try to get the firmware "out" of the burned IC.
Thank you,
Florin
p.s. any other ideas or solutions (eventually new schema+firmware) are very wellcome.
Hmm, I think that's one giant leap for deductive reasoning!
I think you need to take it off the board to see if there's anything written underneath
Even if you can identify the chip I forsee two very large stumbling blocks:
1) in almost every commercial project the lockbits on the AVR will have been set so no one can extract the code (prevents making copies)
2) even if the code were unlocked if the chip really has been "blown up" by the application of 12V then how on earth could you extract the current code anyway ?
In my opinion, duplicating the firmware is not difficult. The hard part is maybe doing that without having a working unit to analyse. It's possible that there is some "magic" in the firmware that drives the PWM in a specific way which is related to the attached hardware.
It's also possible that if driven incorrectly by the firmware, the hardware (the nail polisher) will be damaged, so that's something to think about.
Total votes: 2
That pinout could just as easily be a PIC.
There is a code on the back side 1 85256C or 1 85356C. Tried to google but nothing found, as expected.
Hi Brian,
I have search and the only microcontroller with pin 1 VDD and 14 GND is Attiny. But, if you have any idea about a PIC with this setup, please let me know.
I'm willing to try to re-design the circuit in order to use a different chip, but unfortunately I have just entered into this "world".
Florin
But you're speaking as someone experienced in the art;
Let's say that I think I have the tools to do it. And, according to "if there is a will there's a way", I'll do my best to learn how to do it.
GND is also known as Vss. There are 45 different 8-bit PICs in a 14 pin package but most (all?) have the power pins arranged like this...
dabijja wrote:
Hi everybody,
Well, good job on reverse engineering it, even though it looks like the layout is very simple to reverse engineer and clear.
I'm sure there are multiple options for 14-pin soic which will fit in that space. Attiny1614 is one of them. At least where I live (UK) it is possible to buy attiny1614 in quantities of 10 for about $1 each.
Actually trying to implement this controller is more difficult of course, you will probably need build some kind of development board (order a devkit of some kind?) and check that the correct signal is coming from the correct pin, getting the adc right etc, before putting it in-circuit.
I'd probably try to put bodge wires across to a breakout-board or something, and wire some LEDs (on a prototype or breadboard) to check the output signals visually, with the pedal switch in-circuit.
It is rather a shame they didn't put a software-controllable LED on that board.
You have just added more options :)
Thank you!
it took some days :). Thx
I have recently bought an Mplab Snap and MSP-EXP430FR4133 (dev board) in order to play with them so I think they can help the scope.
That's an odd combination!
surprise
When I read that I was thinking of this:
Why  would someone want to polish these.....
Oh well, what ever floats your boat I guess smiley
Good luck with your project
laugh
The two potentiometers don't appear to be connected to anything.
Can you get the motor spinning by putting +5V on R6 and/or R7?  (with the power on to the rest of the circuit?)
If the 14-pin IC is a microcontroller, it could be a tiny24/44/84.  In that case a replacement could be programmed with a common cheap ISP programmer such as the USB-ASP.
You're correct. half of the potentiometer is not connected but the other half is connected to pin 3 with a resistor R4 (I have now corrected the diagram). Thank you very much for your input.
I shall test it and let you know.
Looks like you should have a do-able project to add in your own chip and  code---with your own features!
To make things smoother, now that you have some sense of how things are connected, redraw it nice and neat (it is somewhat horribly scrambled now).  Put the AVR in the dead center and everything will radiate out from it (it is the central control point of all)...all of the  twisting & turning wires will be nice, short and straight connections (such as from the AVR to the motor chip, from the pots to the adc pins, etc).  You will be amazed it how much it will clean up.  It will also make any other missing or oddball things easier to spot.
Yes, the motor is spinning on both directions by putting +5V on R6 and then on R7.
I'll do that (this might be easiest thing for now laugh). Thank you
Generally speaking inputs on the left, output on the right...signals & schematic flows from left to right, just like reading a book...except you are reading wires connecting things together.
You can also move (reorder) the pin #'s  on your chip symbol, that gives it the ultimate clarity (ex: pins on left side numbered as: 1 2 6 8 3 12 10 5... I made these up).
as per your input, I have managed to redraw the circuit.
Now, I need to find a solution. cool
Plus goes to the top, ground goes to the bottom. Half of your circuit is upside down - makes it difficult to understand.
I hope is better now.
With the MPlab SNAP you should be able to program a 14-pin AVR microcontroller with Vcc and Gnd on the correct pins.  An example is the Tiny24. Seems like one ADC channel needs to be read[speed], a direction switch, and a motor/on/off push switch.   Then output logic is sent to the motor controller IC.
I would just use one pot, with the center position as motor stop (have a small dead band there), less then middle position would be reverse, greater then middle position forward (joy stick pot)
The further from center, the faster the motor would run.....
ki0bk wrote:
(joy stick pot)
My bad, I see you already have forward/backward switch, and pot sets a desired nail polishing speed, I was thinking about a robot motor control.....
Your input is really valuable but could you please provide me with an example of such code? In the meantime I'll look for few Attiny to order. Thank you
You just need a chip that has power pins on the correct pins (1,14)....adc on pins 3,  ????
For your schematic (it is beginning to get a lot better):
pin 7 is not the best direction, it should be more like pin 6  ...inputs go from left to right.
Why are the wires rising so high from pins 4 & 3, but then at c1  & r5, the distance is crushed to nothing? ,very unbalanced.
Just like a GND symbol is used, do the same for +5V   symbol...will be a LOT cleaner looking
U3 pin 1 gnd...crosses bunch of other wires unnecessarily
C4 missing dot to gnd
Where is connector pin1 , pin2 on the schematic?
Q2...the base should be on the left...the entire circuit block is mirrored....r10, r8, c6, etc should be on the left, r11, c8 on the right
R17 should be centered between pins 12 & 14.
Connection dots go to wires, not components..BOTH/ALL leads of components should only go to wires
For things like pedal 2 there is a slight preference for the signal to be on the left and the gnd on the right
Thank you very much for your help, so far. While I'm trying to find some time in order to get the diagram in the best possible shape (thx to @avrcandies), I have just received several Attiny in order to play with them.
Now, based on the current scheme, can anybody provide me with some links from where I can get some instructions, best practices that can match my project?
One option, based on my research, might be to get the project done for Arduino and than to import it in Atmel Studio and  compile it for Attiny24 (for example). Of course, if somebody can help me with creating the code directly in Atmel, that will be much appreciated.
Thank you
Hi everybody,
Unfortunately, no progress on this project. Is anybody willing to help? A beer or two or three can be "granted".
Thank you,
Florin
