Atmega32u4 with LUFA Dual CDC
2 posts / 0 new
Hi everyone,
i need some help on CDC USB application development on atmega32u4, i want to open two virtual port when device connected to Host and it can be able to send string on both virtual port. i have search lot of example on LUFA libary on CDC but not get any idea how i can open two virtual CDC port simultaneously . Thanks for any help.
Topic locked
