Now a days Why do most companies prefer c++ over C
28 posts / 0 new
Hi
I have searched through a lot of job posting ads and found that most recruiters’ prefer C++ over C language in embedded system. I do not understand What is the reason that they are preferring projects in C ++?
Because C++ is a "better" language. It applies "object encapsulation" to basic C to make it more modular, testable and robust. It was developed some years after C first appeared and was therefore able to "fix" some of the things that could too easily lead to bugs in plain C.
Clearly you cannot be familiar with both C and C++ if you don't already understand what makes C++ a more desirable language. I'd suggest learning some of the basics of C++ to get a better understanding of why it is preferred.
Total votes: 2
It is simple -- those that want to gain/retain more power over others decree that something newer (newer than perfectly functional [and at this point traditional] procedural languages) be used.  Like the pointy-haired boss, they can spew terms like "polymorphism" and feel cool.
...and https://www.google.com/search?q=...
Acolytes and minions can be mustered to devote years -- nay, decades -- to try to coerce simple tasks to be done in a manner approaching the simplicity and efficiency of more traditional approaches.  [ref.: ralphd]
Total votes: 3
laugh laugh laugh laugh laugh laugh
most recruiters wouldn't know a C++ if their inheritance depended upon it!
Total votes: 2
Tell them C++ is old hat and you have moved on to using PL/1
Recruiters generally prefer you to not ask a lot of questions....just take the job so they can collect.
You'll be saying C++ is for Quiche Eaters next ...
Total votes: 2
I'm glad I was not drinking something at the time I read that!  surprise
Total votes: 2
Well, "C++ is a superset of C, so anyone who knows C++ can also program in C."
Not true, in many ways, but exactly the sort of thing that recruiters and/or HR departments would think.
muke12 wrote:
in embedded system
You keep saying that:
https://www.avrfreaks.net/forum/kernel-programming-experience
https://www.avrfreaks.net/forum/do-you-have-experience-device-driver-development
as if "embedded system" had some single, strictly well-defined, precise meaning.
Of course, it is not at all !
"embedded systems" covers a vast spectrum from tiny little processors with only a few hundred bytes of memory right up to huge systems running major operating systems like Linux.
Clearly, the choice of programming language, etc, will vary widely across that spectrum.
I work in embedded systems and I work (almost) exclusively in C++. It's true that I use GHz, Octo-core processor surround by advanced vision processors - but it's still "embedded" (this goes under the bonnet of your car and once there the code will not change).
Total votes: 2
And at the other end of the scale I'm currently sitting here writing code, in plain old vanilla C,  to go in a tiny4313, running at 7.4MHz, which scans a 16-key keypad and outputs to an I2C lcd display and a serial port. Likewise, once shipped it will never change.
Total votes: 2
Absolutely.
But it's a far cry from the humble 8-bit AVR - where the are people still debating whether 'C' is worthwhile ...
Are there still people making 4-bit micros ... ?
Sorry - that image is too small to read.
frown
https://www.google.dk/url?sa=i&u...
But it kind of look too even (don't expect 16bit to be that big)
I would expect that most "small" micros today are pad limited, so no extra cost to make a bigger micro ( >4 ) bit. But there would be many cheap very high volume (real ROM mask (no otp or flash)) productions going on.
Add
It's 20 years since I last programmed a 4 bit micro (a samsung otp)
Another attempt to paste a "big version"....
is it me or does that REALLY shows that 4 bit seems to be growing faster than 8 bit ??
each has about 20% of market share. Interesting plot. This means that all of them are utilized in their suitable areas.
work in progress...
Hmmm ... a google image search for that image gives this:
So I think the whole thing may be spurious?
Probably you have to cough up the cash for the report to see the real graphs ?
frown
EDIT
I also had to take a 2nd attempt at pasting the image
Going on 30 for me - NEC uPD75..., IIRC ...
that's a lot of time! Does it still make fun for you to work in the field,  or do you still actively developing?
work in progress...
I just had a look at aliexpress to see
And they have this for $0.1
SD6832 DIP8 In Stock 4BIT MICROCONTROLLER
I don't know anything about the chip other than it is :
PWM+PFM controller with built-in high- voltage MOSFET
But this one of the things that keep the count up :)
Amazed that there are still 4-bit applications! Next thing, you-all will be telling me that bit-slice is the next big thing! Anyone for a 19-bit "micro"?
Let them know you can also do assembly...they may be impressed, because it has become a rarer commodity.   Too many "PC folks" jump in not understanding what is really going on & are "lost" without a library to lean on.
Not saying a library isn't useful or needed, but please be able to do basic things without one.
Employers prefer C++ over C because Arduino uses C++ and they have finally realized that they can hire competent Arduino programmers for 1/10th of the cost that they pay C programmers and still get the about the same amount of programmer productivity.
laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh laugh
I looked at the datasheet but didn't see any indication that the SD6822 is a microcontroller of any type.  Sure there are a lot of factories in China that will sell you a box of left-over chips for a penny each.   But don't expect them to be able to tell you what they are, what they do, or if they are defective, counterfeit and/or maybe completely unmarked.   Ebay has the SD6822 selling for about a dollar/pound/euro a chip.
There are twenty-cent microprocessors available.  They sometimes have ADCs and high-current I/O pins.   They are usually One-Time-Programmable and have custom instruction sets with complex and underdocumented programming procedures.
