STK500 - Atmega8 - Invalid Device Signature
10 posts / 0 new
when trying to program via avrdude and STK500 my ATMEGA8
avrdude -p atmega8 -c stk500 -P /dev/ttyUSB0 -U first.out -F
I get an error message regarding invalide device signature: (attached the whole, verbose output)
avrdude: stk500v2_command(): command failed
avrdude: Device signature = 0x70f049
avrdude: Expected signature for ATmega8 is 1E 93 07
Unfortunately the device signature reported by avrdude (0x70f049) changes each time.
Same problem when replacing the Atmega8 with an Atmega16.
The STK itself seem to work, as the program which is currenylt on the Microcontroller works, and the status LED is green.
My setup already worked. But i think I broke it/the STK when i attach a stepmotor to the Atmega.. :( The Status Led switched immediately to red (short circuit), I assume this was because too much current has been drained..
Is there a way to fix this?
Welcome to AVRFreaks!
Fix what, the signature not reading or the short circuit?
Begin here to see how to ask questions: https://www.avrfreaks.net/forum/...
What does your motor driver circuit look like (what chips or transistors)? you could feedback high voltage spikkes that damaged things.
Do things return to normal with all of that disconnected (assume no , you prob already tried that)
Thank you for the replies
The short curcuit is already removed, i removed the step motor and the corresponding driver.
I already reomved the motor driver curcuit, so the problem appears when only using STK500, Atmega8 and attached LEDS PORTB.
What I would to 'fix' is to enable programming of my Atmega again, which most likely corresponds to the read signature.
I would try a new atmega if you can not read its signature then your stk500 is broken!
Yeah, new Atmega is not changing anything. Too bad... in that case I guess i have to throw it away.. Thanks tho
Is it still red with all the motor stuff removed? If green, there is hope
When starting the STK, the Status LED switches from Red - Orange - Green - Off - Green and stays Green.
Have you tried using it with Atmel Studio?
I will try that as soon as I have a windows machine running :) I'll come back, thanks!
