Disabled Reset pin while debugWire was enabled
11 posts / 0 new
Hi everybody,
I just tumbled into a little dead lock that probably some of you guys know a solution too ... I'm actually surprised that I couldn't find the solution by searching the web already. Am I really the only one whos dum enough to do something like this?
Anyways, here's what happened
I'm currently debugging an ISR to trigger an external watchdog. I tried to get some more details by accessing my Atmega328bp via debug wire. I could set breakpoints and so forth but the behaviour was somewhat flaky. I though "maybe it's the Watchdog interfering with the debug wire, cause they boath have access to the reset line right?!" so I disabled the reset pin and tadaaaa got stuck. Now I can't access the Atmega either via DebugWire nor via SPI, due to the debugWire and ResetDsiable Fuse being set (at least that's my assumption)
Is there any trick how I can access the fuses now so I can disable the debugWire or ResetDisable Fuse? Unfortunately I only have an Atmel-ICE programmer so HVPP is not available I guess?!
Any help would be highly appreciated,
thanks,
Lenn
Well, of course a watchdog is going to interfere with your debug session!
The whole point of a watchdog is precisely to reset the CPU if your code becomes unresponsive - and, by definition, it will be unresponsive if you halt it with a debugger!
This is the same for any chip. It is especially true when you use an external watchdog - because you can't just disable that by having a DEBUG build with the watchdog disabled.
Dudovitz wrote:
cause they both have access to the reset line right?!
Not really. Usually, the WD reset is distinct from the external reset line,
A really bad move!
The external reset pin is essential to the operation of the debug interface - so, if you disable that, you have no debug access!
Once you've disabled the external reset, HV programming is your only option:
https://www.avrfreaks.net/forum/tutsoft-recovering-locked-out-avr
EDIT
In the Tutorial, clawson wrote:
Perhaps the most insidious of all the fuses is the one found on low pin count AVRs called RSTDISBL. Because these AVRs have so few pins they can sacrifice the use of the _RESET pin to be used (usually) as another GPIO pin instead. The problem is that ISP works by holding the chip in reset and it does this by pulling the _RESET pin low. If that pin has now been disconnected from the internal _RESET signal in favour of using it as an I/O then you simply cannot start ISP ever again in order to recover the situation.
Total votes: 2
This is where STK500 ownership still pays dividends - it can do HVPP (assuming you can lift the chip and plug it into the socket - trying to connect the 20 wires to a chip "in-situ" is close to impossible.
To be honest most people who make the RSTDISBL mistake only make it once, they throw away the $2 micro and chalk it up to experience !
Total votes: 2
The ATmega328PB is only available in SMD.    So you would have to remove the chip.  Solder it on a DIP adapter for the STK500.    Perform HVPP.   Remove the chip from the DIP adapter.  Solder it back on your pcb.
I would buy another chip.   Much easier.
Never touch RSTDISBL again.
DebugWire shares the /RESET pin, but the watchdog triggers a reset internally.  The /RESET pin has nothing at all to do with it.
Joey, he is using an EXTERNAL watchdog chip!
Either I missed that (entirely possible), or the edit to the OP added that after my reply in #1.
Of course, when you have an external watchdog you must have some way to disconnect it for debugging!
Again, that applies to any processor - but especially so if you're going to use debugWIRE !
And it is clearly stated in the datasheet:
EDIT
Jacl Ganssle wrote:
Everyone knows we should include a jumper to disable the [external] WDT during debugging
http://www.ganssle.com/watchdogs.htm
EDIT 2
And see that article for why kicking the WD from an interrupt is unlikely to be a Good Thing ...
Yup, missed it!
HUIIII
thanks for all these enlightning answers!
Turned out to be what I had to do.  And I even added some solder experience to it. Isn't that grate :-P The HVPP is not supported by the Atmega-ICE and after some thoughts it turned quite clear that disbaling the reset pin WHILE having DWEN set is probably the easiest way to turn you're $2 into a piece of junk.  Wouldn't happen again. I promise ;-)
Thank you guys so much for taking the time to explain. Really appreciate it!
Actually, disabling the reset pin at any time is probably the easiest way to turn your $2 into a piece of junk
You're welcome.
Now please see Tip #5 in my signature
woops. Sorry!
