Live Watch
4 posts / 0 new
I'm using an ATtiny1616. I am trying to use the live watch but it won't accept any variable usually. When it does it says something like 'Data breakpoints not supported for this interface'.
What does this mean? The micro doesn't support this or is it the Atmel Ice UPDI interface?
Can I find out the set of tools that do support this feature?
This feature uses data breakpoints. The ATtiny1616 doesn't have any.
:: Morten
Thanks!
