__STDC_VERSION__ not defined in avr-gcc project?
13 posts / 0 new
Hi guys,
I'm moving over from PetitFs to FatFS (as per thread https://www.avrfreaks.net/forum/failing-pfmount-using-petitfs-cannot-determine-why).
The first major hurdle I'm having is trying to get the whole package compiled due to the following. ff.h contains the typedefs for integer types used by FatFS; however, all the types throw compilation errors due to unknown type names, and searching my entire project including all dependencies, I cannot find __STDC_VERSION__ defined anywhere?
Do I have to provide this definition myself? I've searched the entire ffsample code, including makefiles - and nowhere is this defined, only tested. I'm clearly not expected _WIN32 to be defined, using the avr-gcc Toolchain inside AS7.
/* Integer types used for FatFs API */
#if defined(_WIN32)	/* Main development platform */
#define FF_INTDEF 2
#include <windows.h>
typedef unsigned __int64 QWORD;
#elif (defined(__STDC_VERSION__) && __STDC_VERSION__ >= 199901L) || defined(__cplusplus)	/* C99 or later */
#else
#define FF_INTDEF 2
#include <stdint.h>
typedef unsigned int	UINT;	/* int must be 16-bit or 32-bit */
typedef unsigned char	BYTE;	/* char must be 8-bit */
typedef uint16_t		WORD;	/* 16-bit unsigned integer */
typedef uint32_t		DWORD;	/* 32-bit unsigned integer */
typedef uint64_t		QWORD;	/* 64-bit unsigned integer */
typedef WORD			WCHAR;	/* UTF-16 character type */
#else  	/* Earlier than C99 */
#define FF_INTDEF 1
typedef unsigned short	WORD;	/* 16-bit unsigned integer */
typedef unsigned long	DWORD;	/* 32-bit unsigned integer */
#endif
Things that start with two underscores generally belong to the compiler so I think you'll find this is auto defined at compile time. Try the -E -dM trick to check.
EDIT: now back at computer so:
That code block looks wrong to me ... it certainly triggers a compilation error with the g++ I have at hand.
#if
#elif
#else
#else
#endif
exit status 1
#else after #else
Would it not be easier to hack that .h file for now and worry about 'doing it properly' later ?
Thanks both,
That's exactly what I've done - I know I'm using gnu99 C so I've just commented out the other bits.
I will come back to it to fix however as I hate leaving bits lying around like this.
I tend to add a keyword  that can be grep'd when I make changes that need to be "fixed" later.
I tend to use ###.
In Eclipse, if you put TODO: in  comments, it automatically gathers them all together into a "To Do" list
Dunno if Atmel/Visual Studio has a similar feature? or VAssist ?
Yes AS7 inherits the TODO thing from VS
It does so with HACK also which I tend to use to differentiate from general to-dos.
Somewhere in preferences you can add to the list of keywords also if you wish to use any other keyword.
EDIT - Oops, just noticed you posted a link to the actual preference, awneil.
Running any avr-gcc command within command prompt for me returns only an unknown command error, I assume to be able to run this - you have to install the avr-gcc toolchain into Windows, rather than working within AS only?
Is your PATH set to find them?
If not, entering the full path+filename should do it
Or CD to the folder where the .exe lives ...
In your Start menu, in the Atmel Studio 7 folder, you should have an 'Atmel Studio 7 Command Prompt'
That will start a command prompt with a corectly-configured environment.
EDIT
The Atmel Studio install doesn't, apparently, include grep - so you'd have to get that from elsewhere ...
EDIT 2
Or just do it the Windows way:
note the need for quotes on a path with spaces ...
frown
Ah, this looks like it should do the trick. Will confirm tomorrow when back at the PC.
I was simply using a 'normal' Windows CMD Window, without any CD command to anything but default directory, somewhat naively in hindsight.
Edit - Just seen your 'EDIT 2' - will make sure I try both methods tomorrow to embed it in my head!
Thanks for your input!
So, having learned something in the form of the -E -dM command set, I can see that as expected my STDC version is > 199901.
avr-gcc -E -dM - < NUL | find "STDC"
#define __STDC_HOSTED__ 1
#define __STDC_UTF_16__ 1
#define __GNUC_STDC_INLINE__ 1
#define __STDC_VERSION__ 201112L
#define __STDC_UTF_32__ 1
#define __STDC__ 1
Having sorted the #ifdef #else #else issue, code compiles fine now. Cheers!
