SAME54 async adc
4 posts / 0 new
I'm trying to get the adc working with multiple channels, but I'm getting stuck.
I'm using the async adc. I'm using the SamE54 chip
These are my defines:
/* The channel amount for ADC */
#define ADC_0_CH_AMOUNT 16
/* The buffer size for ADC */
#define ADC_0_BUFFER_SIZE 16
/* The maximal channel number of enabled channels */
#define ADC_0_CH_MAX 15
struct adc_async_descriptor         ADC_0;
struct adc_async_channel_descriptor ADC_0_ch[ADC_0_CH_AMOUNT];
static uint8_t ADC_0_buffer[ADC_0_BUFFER_SIZE];
static uint8_t ADC_0_buffer2[ADC_0_BUFFER_SIZE];
static uint8_t ADC_0_map[ADC_0_CH_MAX + 1];
This is part of the code:
hri_mclk_set_APBDMASK_ADC0_bit(MCLK);
hri_gclk_write_PCHCTRL_reg(GCLK, ADC0_GCLK_ID, CONF_GCLK_ADC0_SRC | (1 << GCLK_PCHCTRL_CHEN_Pos));
// Disable digital pin circuitry
gpio_set_pin_direction(VREAD, GPIO_DIRECTION_OFF);
gpio_set_pin_direction(VBAT, GPIO_DIRECTION_OFF);
gpio_set_pin_direction(VIN, GPIO_DIRECTION_OFF);
gpio_set_pin_direction(VEXT, GPIO_DIRECTION_OFF);
gpio_set_pin_function(VREAD,PINMUX_PA03B_ADC0_AIN1);
gpio_set_pin_function(VBAT, PINMUX_PB03B_ADC0_AIN15);
adc_async_init(&ADC_0, ADC0, ADC_0_map, ADC_0_CH_MAX, ADC_0_CH_AMOUNT, &ADC_0_ch[0], (void *)NULL);
adc_async_register_channel_buffer(&ADC_0, 0, ADC_0_buffer, ADC_0_BUFFER_SIZE);
adc_async_register_channel_buffer(&ADC_0, 1, ADC_0_buffer2, ADC_0_BUFFER_SIZE);
adc_async_set_inputs(&ADC_0,ADC_INPUTCTRL_MUXPOS_AIN1_Val, ADC_INPUTCTRL_MUXNEG_GND_Val, 0);
adc_async_set_inputs(&ADC_0,ADC_INPUTCTRL_MUXPOS_AIN15_Val, ADC_INPUTCTRL_MUXNEG_GND_Val, 1);
adc_async_enable_channel(&ADC_0, 0);
adc_async_register_callback(&ADC_0, 0, ADC_ASYNC_CONVERT_CB, convert_cb_ADC_0);
adc_async_enable_channel(&ADC_0, 1);
adc_async_register_callback(&ADC_0, 1, ADC_ASYNC_CONVERT_CB, convert_cb_ADC_1);
adc_async_start_conversion(&ADC_0);
But only callback for channel 0 is called
I'm probably missing something obvious.
Thanks in advance.
There are multiple inputs but not multiple channels (for SAME54), you would notice this if you follow the code to the implementation, e.g. :
 * \brief Enable ADC
void _adc_async_enable_channel(struct _adc_async_device *const device, const uint8_t channel)
    (void)channel;
    hri_adc_set_CTRLA_ENABLE_bit(device->hw);
/Lars
Thanks, but the SamE54 datasheet says:
Dual 12-bit, 1 MSPS Analog-to-Digital Converter (ADC) with up to 16 channels each
ASF doesn't implement/ use the channel system?
It's just about naming, the channel concept in the start API is not applicable to the SAME54. Use adc_async_set_inputs. You can also look at the start example which does this using DMA.
/Lars
