Hello to all,
sorry for my bad english, as the title suggests, I need someone to modify the code for an attiny10, I can't do it, the code is used to drive a led driver made with QX5241, I have attached the code that I found but it doesn't work as I want and I don't know how to fix it, I need these features,
three-level ignition,
off,
1 - 100%
2 - 60%
3 - 30%
off
the driver can be powered indifferently with 2s or 3s battery packs, if possible I would like there was a way that the software identifies which battery pack is there at that moment and when it reaches a limit volt value of 6.5v x 2s and 9 75v x 3s lower the light to 50% to save battery
the software must also have the debouce to avoid accidental switching on
and must also have sleep when it is turned off to save batteries.
I hope someone does this to me
Thank you
//v0 5/1/2014 by Everett //initial version //simple flashlight controller. mode change on power cycle //v1 5/3/2014 by Everett //adapted to momentary switch //v2 5/6/2014 by Everett //ported to Attiny10 device #define F_CPU 1000000 #define pwm OCR0BL #define pwm_invert #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> #include <avr/sleep.h> unsigned char mode; enum mode{ max=0, med=1, low=2, off=3, }; #define max_mode 3 #define default_mode 0 unsigned int v_timer; char v_sample; #define voltage_rate 100 //milliseconds char pressed; char new_press; char switch_count; unsigned char isr_prescale; void configure(void); unsigned char read_voltage(void); void initialize_mode(void); void debounce(void); void shutdown(void); ISR(TIM0_OVF_vect) //fires at 4kHz { isr_prescale++; if(isr_prescale>=4){ //prescale since timer only has the 4kHz option isr_prescale=0; debounce(); if(++v_timer==voltage_rate){v_timer=0; v_sample=1;} } } ISR(INT0_vect) { //no action, but ISR must be included since it will execute upon waking } int main(void) { configure(); //set up hardware peripherals mode=default_mode; initialize_mode(); pressed=0; new_press=0; switch_count=10; sei(); //turn on interrupts while(1){ if(v_sample){ v_sample=0; if(mode==max){ //if battery goes below threshold in max mode, force down to medium mode if(read_voltage()<100){ //set threshold for external voltage here mode=med; initialize_mode(); } } } if(new_press){ new_press=0; mode++; if(mode>max_mode) mode=0; initialize_mode(); } if(mode==off) { shutdown(); //shutdown will lock up here until a press wakes the device } } } void shutdown(void) { TIMSK0=0; //stop timer interrupt pwm=0; //zero output TCCR0A=0; //turn off pwm #ifdef pwm_invert PORTB|=0b00000010; #else PORTB=0; //ensure pin is low #endif ADCSRA=0; //adc off PRR=3; //power reduce on adc and timer0 while(1) //make this a loop so we stay here until sure the switch went down { do{ debounce(); _delay_ms((char)1); }while(pressed); //ensure switch is up EICRA=0; //interrupt on low level of int0 EIMSK=1; SMCR=0b00000101; //enable sleep sleep_cpu(); EIMSK=0; SMCR=0b00000100; //disable sleep pressed=0; switch_count=10; for(char i=0; i<40; i++){ //watch for up to 40ms for a solid press debounce(); _delay_ms((char)1); if(pressed) break; //if pressed break out of for loop } if(pressed) break; //if pressed break out of sleep loop } configure(); //set up hardware for operation } void debounce(void) { static char port_copy=0xff; #define switch_mask 0b00000001 //this selects PB0 as the switch if((PINB&switch_mask)==port_copy) //if the current state matches previous state { if(--switch_count==0) //count down samples. if 10 consecutive samples matched { switch_count=10; //reset sample counter if(PINB&switch_mask) pressed=0; //if the state is high, switch is up else //else switch is down. check for new press { if(pressed==0) new_press=1; //if last state of pressed was 0, this is a new press pressed=1; //switch is now down } } } else //state doesn't match, { switch_count=10; //reset sample counter port_copy=(PINB&switch_mask); //get new sample } } void initialize_mode(void) { switch(mode){ //initialize current mode default: case max: pwm=255; break; case med: pwm=25; break; case low: pwm=1; break; case off: pwm=0; break; } } unsigned char read_voltage(void) { ADCSRA|=(1<<ADSC); while(ADCSRA&(1<<ADSC)); return ADCL; } void configure(void) { PRR=0; TIMSK0=0b00000001; //interrupt on t0 overflow pwm=0; #ifdef pwm_invert TCCR0A=0b00110001; //output B inverted #else TCCR0A=0b00100001; //output B on, not inverted, 8bit pwm, #endif TCCR0B=0b00001001; //no prescale for 3906Hz pwm and interrupt GTCCR=0; PORTB=0; DDRB=0b00000010; //PB1 output DIDR0=0b00000100; //PB2 analog PUEB=0b11111001; //pull up switch and reset ADMUX=2; //PB2 ADCSRA=0b10000011; // SMCR=0b00000100; //enable power down mode }
