Latch On until load current continues
10 posts / 0 new
Hello guys...I am wondering how to do this without burning a lot of brain cells. If there is an simple standard circuit I could use, it would be handy.
Basically I need the following:
- Atmega pin turns on a mosfet controlled load.
- Load is a motor that carries on doing something and eventually turns of by itself, so the current will drop.
- Atmega may or may not need to hold the IO pin to drive the motor.
- So some sort of latch circuit could do the tick. But the latch must turn off once the motor drops the current.
- It would be good to have some overcurrent measurement capability as well.
Use an SCR or thyristor instead ?
Needs to be DC circuit...DC motor control.
To make it complicated I need to make it run in reverse direction as well.
That's why I said SCR or Thyristor - not Triac.
Ok I will look into SCR/Thyristor option.
I thought this could be neat circuit: https://www.edn.com/latching-pow...
Just need to remove C1 and R2.
That does not do what you stated in the OP: it's a "push for on; push again for off" - it's not a "hold until the load stops".
So is that what you want?
which is why i said we need to remove C1 and R2 (to get rid of push to off 2nd time).
That will stop it latching at all - it won't make it sensitive to the load!
Use the ADC to monitor current...If you can control the pins to turn on the motor, why do you need a "latch circuit"---just keep the pins high.  Obviously if a motor is running, plenty of power is avail, so its not like the AVR is becoming unpowered.
You have an AVR at your disposal--use it!
