How to use light_ws2812 in C++
19 posts / 0 new
Hello everyone!
I have a question:
How do I use the light_ws2812 library ( https://github.com/cpldcpu/light_ws2812) in C++ code with my ATMega2560 in Atmel Studio???
I have no ideafrown
Thanks for your help
RTFM?
Yes, that I also read, but I mean, how do I use it in code??? I havo no Idea...
presumably there is further documentation in the repository?
and people like Sparkfun & Adafruit have loads of examples & tutorials ...
plenty of previous discussions here, too.
Are the examples in the examples folder not useful ?
Did you search Freaks for light_ws2812? I've done this once before. As I showed there I added the light_ws2812 files to AS7 and got it to build.
Unfortunately not, there are only examples for use in the arduino ide😥
Yes that I also did: #include"WS2812.h" works fine, but I have no idea how to control the LEDs in code, also no examples or suggestions in the documentation of this library, only these written in C😥
No examples? Exactly how hard did you look? I have half an idea the "examples" directory may just have the odd example...
https://github.com/cpldcpu/light...
WS2812 interfacing is high-level programming for the AVR.  It often involves in-line assembler.
Can you describe your hardware platform and your level of programming expertise?  Have you done recursive quick-sorts in another CPU, or are you on the "get LED to blink " level?
Do you have electronics tools available like a digital oscilloscope and PC-based USB logic analyzer?  Do you have experience using them?
  A large percentage of new projects using the Mega2560 use the Arduino Mega platform, because you can get an order-of-magnitude gain in your software output productivity by using pre-written and pre-tested Arduino Mega libraries and examples.   Is there are reason why you can't/won't use the Arduino system for a new ATmega2560 project? Why are you using the ATmega2560 specifically?
Simonetta wrote:
WS2812 interfacing is high-level (sic?) programming for the AVR.
Don't you mean low level ?
Doesn't get much lower than that!
I use "high-level" in this case as a synonym for advanced as in requiring a high level of technical knowledge as opposed to "high level" being a technical classification of the level of data abstraction characteristic to an individual computer language.
The civilized world is ending: give me a break.
Huh? ASM was high level about 40 years ago when I used to enter op-codes via a monitor program. cheeky
Opcodes? Luxury. My first CPU had a latching hex key pad. You had to write the code, hand assemble, then type in the hex pairs (which you could not edit, so had to restart data entry after any mistake)
Likewise.
IIRC, it was a Heathkit ...
(and not actually mine).
and you're here worrying about pretty flashing lights ?
Us uncivilized grubs will live on forever.  devil
Hex pad! What a luxury!
I entered opcodes using the the toggle switches on an Imsai 8080...
David
and you try to tell that to kids o' today ...
frown
