How to solve linker error: sbrk.c(1,1): error: undefined reference to `end'
2 posts / 0 new
I get this linker error message when compiling my project for atsam4n8b:
Invoking: ARM/GNU Linker : 6.3.1
        c:/program files (x86)/atmel/studio/7.0/toolchain/arm/arm-gnu-toolchain/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m\libnosys.a(sbrk.o): In function `_sbrk':
I have tried to search the site and the web but have been unable so far to find a solution. Can anyone please assist? I have attached the linker files.
At first I also ran into problem with __bss_start__ and __bss_end__ but found the solution was to add these to the linker file. But I am puzzled why this was needed in the first place, as I was expexting this to work out of the box. I mean, I have defined any custom segments so shouldn't the default linker file just work?
Kind regards,
Christian
Found the answer myself by reading the linker documentation.
1. There is no need to add  __bss_start__ and __bss_end__ definitions. Use option '--gc-sections' to garbage collect unused section
2. In the linker file add 'end = _sheap;' to the heap section
I am pretty sure that I had tried (2) before writing my initial post (which is why I wrote it because I couldn't get it to work), but when I tried now it worked. Maybe I made a typo the first time
