IC programmer for Nuvoton microcontroller W78E516D
5 posts / 0 new
Hello guys, its been a long time i was here.
Here is my question: I need to flash program into Nuvoton microcontrollers W78E516D. It's pretty old IC, based on 8052 standart. I need an IC-programmer simple inough to build it myself in couple days. Some schematic and programs will be helpfull.
I can not buy somthing ready-to-go, like ChipProg for example. Local market is poor on this things. But also this week our borders was closed for caranteene, nearest 2-3 weeks nothing gets in and out. Appreciate any suggestiones and help.
P.S. I'm into AVR, STM32 and a little Microchip. But I have no time to design IC programmer specialy for Nuvoton from zero. O, one more thing. My chips are empty, so there is no bootloader on board that I can use.
You mean this:  https://www.nuvoton.com/products/microcontrollers/8bit-8051-mcus/standard-8051-series/w78e516d/?__locale=en ?
It says it has ISP - so have you looked for further information about that ?
Have you contacted Nuvoton ?
Not remotely AVR or even Microchip related - have you looked for more relevant forums?
Thanks for reply. Yes, this part. Just wrote to Nuvoton, I hope tomorrow will be answer.
As for ISP, it need to be activated by writing to special register. Here the explaine from datasheet.
If the content of APROM needs to be modified, the W78E058D/516D allows user to activate the In-System Programming (ISP) mode by setting the CHPCON register. The CHPCON is read-only by default, software must write two specific values 87H, then 59H sequentially to the CHPENR register to enable the CHPCON write attribute. Writing CHPENR register with the values except 87H and 59H will close CHPCON register write attribute.
So, apparently, without IC programmer in first place ISP can not be activated.
As for
I'm searching, ofcourse. But nevertheless I came here to ask this question. Any help of society indeed helpfull. Even when question seems dumb inough to some experts. Im not an expert, so asking.
OK, the sky is blue again. I've found an old fashioned IC programmer with LPT. It works fine with W78E516D. Also it was difficult to found an old PC with LPT port on mainboard. The case is closed, thanks.
Please mark post #4 as the solution tehn
JIm
