Need help with ATmega 328PB Xplained Mini
12 posts / 0 new
Dear Community, I need some help
I have a brand new ATmega 328PB Xplained Mini and I connected it to the PC via USB and started Atmel Studio7.
I launched an existig smal project and did a built
Under Tools I selected mEDBG and as interface ISP
In the programmer I selected mEDBG, Device: 328PB Interface: ISP
When I try to read the Device signature I get this Error:
Failed to enter programming mode. ispEnterProgMode: Error status received: Got 0xc0, expected 0x00 (Command has failed to execute on the tool)
Unable to enter programming mode. Verify device selection, interface settings, target power, security bit, and connections to the target device.
I also have a Atmel ICE but nopt connected
Can anybody help?
thanks
Juergen
Is it in debugWIRE mode?
Can you start a debug session ?
Hello awneil sorry for the late answer.
When I set TOOL to: mEDBG and Interface: debugWIRE I can enter DEBUG and debuging seems to work.
When I want to program the device I go to Device programming:
Tool:mEDBK, Device:ATmage328PB, Interface:ISP
I go to memories and press Apply, I receive Error: Erasing device failed
When I try to read the Device signature I get:
thanks for your help
regards
juergen
To program the device using ISP, you need to change the chip from debugWIRE mode to ISP mode:
  1. Start a debug session (in debugWIRE mode)
  2. In the debug session, choose Debug > Disable debugWIRE and Close
  3. Power Cycle The Board!
  4. You are now is ISP mode.
Hello awneil
I followed your instuctions and it works.
When I want to switch back to debugging I get "Launch Failed" with the message ........ Do you want to use SPI to enable DWEN fuse?
After I press YES I am able to continue debugging.
Thank you for your help
regards
Juergen
You're welcome.  I feel your pain - having just been through the same.
I would've linked the old thread from here which gave me the solution - but couldn't find it.
This debugWIRE lark really is a pain, especially with the mEDBG - where the download is so painfully slow!
angry
But it's waaay better on a real Atmel-ICE.
Now please see Tip #5 in my signature (below; may not be visible on mobile)
Whichis the very reason I'd only ever choose "JTAG" chips as JTAG "just works" and you don;t have all the switching back/forth, getting "stuck" malarkey!
Yes - you said that in the thread I was looking for!
But the chip choice was not mine - so I'm stuck with it
frown
I also have a Atmel-ICE, can I use it instead?
I did connect the Atmel ICE together with the USB connection, but I had also trouble with it.
Do I have to disconnect the USB connection to the PC when I use the Atmel-ICE and use a seperate power source?
Look forward to your advice.
regards
juergen
That's really a separate question.
Would be better to mark this thread as resolved (Tip #5), and start a new thread with the new question.
Thank you, I will start a new threat
regards
juergen
JB57 wrote:
start a new threat
surprise
(I think you mean threadwink )
Don't forget to give a link here so people can find it ...
