avrdude + Atmel ICE = Verification Error
13 posts / 0 new
I had to use avrdude for our production site. I created a GUI using python.
Issue is that the verification always fails and the controller doesnt work after programming.
Same controller when I programmed using the Atmel Studio from the same Atmel ICE it works just fine.
controller: ATmega128rfa1
programmer: ATMEL ICE
Command used:
avrdude.exe -e -p m128rfa1 -P usb -c atmelice -U lfuse:w:0xe2:m -U hfuse:w:0x90:m -U efuse:w:0xff:m -U flash:w:D:/HEXFile.hex:i
avrdude.exe: verifying ...
avrdude.exe: verification error, first mismatch at byte 0x0002
             0x02 != 0x52
avrdude.exe: verification error; content mismatch
If you are saying that a command run at the command line behaves different to the identical command invoked within Python then assuming it really is being invoked identically the assumption has to be that the "environment" it runs in is different.
But first to check that it is being invoked the same replace avrdude.exe with something like:
#include <windows.h>
#include <stdio.h>
#include <stdint.h>
int main(int argc, char * argv[])
    for (int i = 0; i < argc; i++) {
        printf("arg: %d, = %s\n", i, argv[i]);
If I build and run that and set the command line arguments to be the same as your command above I see the following both invoking it at the command line and then from within Python:
It looks as if I've got the Python invocation correct as I appear to have got the program to receive identical parameters but I'd suggest you do a check like this to be sure you Python/GUI invocation is the same as the command line invocation.
If it is then I'd suggest that it must be something about the "command environment" that the Python's subprocess.run() generates that is different to your normal command prompt invocation.
Hi thank you so much for very detailed information. However the issue has nothing to do with python.
My concern is the same HEX file with same ATMEL ICE programmer the controller works fine if i use Atmel Studio to program. But if i use AVRDUDE, then the controller doesn't work and AVRDUDE throws verification error.
Difference between working and non working scenarios is AVRDUDE.
The issue happens with or without python invocation.
You could have mentioned that in the first place!
What happens if you program with Atmel Studio, and then just verify with AVRDUDE ?
Or if you program with AVRDUDE, and then verify with Atmel Studio ?
Oh right, apologies - I misunderstood your description. In that case maybe use the AS7 command line tool (atprogram.exe) rather than avrdude.exe ? The command line tool should work the same as AS7 (because basically the GUI invokes it!)
Hi Thank you @awneil, but to suppor the avrdude i had to replace the drivers using 'Zadig' and since then the ATMEL Studio doesnt detect the ATMEL ICE and repair of Atmel Studio didnt help either.
@clawson, I wasnt aware of this. This too doesnt detect the ATMEL ICE as i changed the drivers but as a final solution I may look into this if i dont have other workarounds with AVRDUDE.
Thank you for valuable feedback. I really hope avrdude works
firoz3321 wrote:
... i had to replace the drivers using 'Zadig' and since then the ATMEL Studio doesnt detect the ATMEL ICE ...
ideally a driver re-install from within Atmel Studio
firoz3321 wrote:
... and repair of Atmel Studio didnt help either.
then clean may be the other option
How do I get my Tool to be recognized by Atmel Studio? | Atmel Studio 7
IIRC, the most recent Atmel Studio 7 clean :
Atmel Studio 7 - Problems installing - Application cannot start | AVR Freaks
Hi
I finally am able to get AVRDUDE to work but only if I remove the FUSE settings from avrdude command
Below command with ONLY FUSE Settings is working
avrdude.exe -p m128rfa1 -P usb -c atmelice -U lfuse:w:0xe2:m -U hfuse:w:0x90:m -U efuse:w:0xff:m
This command with ONLY HEX File  is also working:
avrdude.exe -p m128rfa1 -P usb -c atmelice -U fl:w:D:/HEXFile.hex:i
The below Command with both FUSE and HEX doesn't work:
 avrdude.exe -p m128rfa1 -P usb -c atmelice -U lfuse:w:0xe2:m -U hfuse:w:0x90:m -U efuse:w:0xff:m -U flash:w:D:/HEXFile.hex:i
For now, I am sending 2 commands, first I am sending the FUSE command and then the HEX command.
Any suggestions?
Can you please let me know how this can be done ?
It didnt work and that was the first thing i tried and many other ways from many suggestions online too. the device manager Says its detected without any errors but Atmel Studio cannot find it.
Any ways as long as AVRDUDE works i am ok with it.
It will help me if someone can let me know why this works:
avrdude.exe -p m128rfa1 -P usb -c atmelice -U flash:w:D:/HEXFile.hex:i
but this doesnt work ?
You are removing the CHKDIV8 fuse @1MHz and then expecting to program the Flash @8MHz.
I am not sure whether avrdude will speed up between individual commands on the same session.
It should be easy enough to test the avrdude /atmelice behaviour on any regular AVR e.g. a Uno.
The actual ISP operation is a few ms per page. But sending SPI data to a 1MHz target is what slows down the programming.
I suggest that you do fuses and flash in two separate avrdude commands.
Untested. But I am sure that others have discovered the quickest way to do production programming with atprogram.exe or avrdude.exe
I doubt if the 128RFA1 is different to any other chip
I don't think I fully understood. Where am I mentioning the avrdude to flash at 8Mhz ? the FUSES are fixed for end application and any change in fuse setting will not work (Code as Fuse checking)
This is my current implementation. I guess I will continue with this then.
Thank you all for your patience and support.
