Importing Mavlink into Atmel Studios 7
8 posts / 0 new
Hey guys, I was hoping someone could help me with importing this library. When I follow the guide,  https://mavlink.io/en/mavgen_c/ , it says add to your project and then just use #include. I've tried adding it as a library, and tried moving it into the same location as my c file, but it doesn't recognize the #include. Also how would I go about creating a parent dialect and adding it? Thank you in advance!
You #include header files and you "add" code files to the project by right-clicking on the project name in the solution explorer.
Not sure what you do about assembler files.
In the link that you posted, it shows:
   #include <your_dialect/mavlink.h>
If you are using Studio 7, using the < ... > is wrong.
Try using " ... " instead.
   #include "your_dialect/mavlink.h"
Thank you for the suggestion, I tried adding existing file already and I tried once more but it does not work unfortunately.
Thank you for the suggestion, I changed it to " " and it still did not work unfortunately.
What are the reported errors? You can copy from the error window and paste into your Freaks message.
When I do #define "common/mavlink.h"
Severity    Code    Description    Project    File    Line
Error        recipe for target 'main.o' failed    C    C:\Users\Chris\Documents\junior_design\C\C\Debug\Makefile    76
Error        common/mavlink.h: No such file or directory    C    C:\Users\Chris\Documents\junior_design\C\C\main.c    2
When I do #define "common.h"
Error        #error Wrong include order: MAVLINK_COMMON.H MUST NOT BE DIRECTLY USED. Include mavlink.h from the same directory instead or set ALL AND EVERY defines from MAVLINK.H manually accordingly, including the #define MAVLINK_H call.    C    C:\Users\Chris\Documents\junior_design\C\C\common.h    10
Error        ../protocol.h: No such file or directory    C    C:\Users\Chris\Documents\junior_design\C\C\common.h    30
When I do #define "mavlink.h"
Error        version.h: No such file or directory    C    C:\Users\Chris\Documents\junior_design\C\C\mavlink.h    31
https://imgur.com/a/D1hryPl
https://imgur.com/a/eKdBSw9
I just tried this and got this error
https://imgur.com/a/2wHAdUr
Error        recipe for target 'C.elf' failed    C    C:\Users\Chris\Documents\junior_design\C\C\Debug\Makefile    106
Error        cannot find -lcommon.h    C        1
Error        cannot find -lmavlink.h    C        1
Error        ld returned 1 exit status    C    collect2.exe    0
Not #define. That is for macros.
#include "common/mavlink.h"
The IDE might not like locating in a subfolder but have not tried it.
Also, note that the IDE uses "\" which is the Windoze symbol. So, you might want to
#include "common\mavlink.h"
