Hex to ASM utility badly needed
6 posts / 0 new
Thanks for looking. I've written an assembler project to control an XMEGA-A3BU Xplained board. I got the program working, but then had to put it away for a few years.  Then, the hard disk crashed and I lost the source code. Shame on me. I was able to download the hex file from an XPlained board using the latest version of Atmel studio, but cannot duplicate one user's experience in AVR studio wherein the program recreated an assembler file based on the hex file contents.  I was able to find other .asm versions that do not work, but if I could get this hex file into AVR assembler format, I could get the program back into original form and working. Can anyone here assist me with this?  I understand someone wrote such a program (converts .hex to .asm file format), but I have not had luck trying to download from the link supplied (went to a Chinese site). It is used as a controller for a multiband amateur radio, with OLED display and 3 DDS boards. I would really appreciate help here, as I spent over 6 months getting this working, and have now lost the source.
Thanks, Fred
Assuming you have the avr-gcc tools installed:
avr-objcopy -I ihex -O elf32-avr wo.hex wo.o
avr-objdump -D wo.o  >wo.txt
and then spend some time post-processing the asm dump.
Mike
It's called a disassembler.
There have been many previous such requests; eg, only last week:
https://www.avrfreaks.net/forum/current-avr-codedata-seeking-disassemblers
As  mha11 showed, objcopy/objdump can do it.
Other disassemblers are available; in fact, if you load the hex file in the Atmel Studio simulator or debugger, it will show you a disassembly view.
But note that a disassembler cannot reconstruct any of your symbolic information - variable names, etc - it will be just raw instruction mnemonics and hex values.
And disassemblers have a hard job telling data in flash from executable code, so it's likely to take a lot of work on your part to get it right - " post-processin", as   mha11 said.
Start figuring out the names of each register & inserting into you code (ex:  r21==>motor_rpm, r23==>batt_volts), that will help immensely to see what is going on.  Same thing with any flag bit registers you made & anything stored in ram, if you used that.  Since you wrote the code, it will all come back.  The hardest part might be the lack of comments.   But you say you already have a slightly older version?  That will help a LOT.
Thank you for the help.  Now I've got some work to do.
Regards, Fred
In #2 you also want the correct -m to specify the right architecture for A3BU
