a<b<c in if
14 posts / 0 new
Dear all,
if(a<b<=c) {statement}   is it OK?
it means condition statement a<b<c in if is OK or should be if(a<b && b<c) ???
It is syntactically valid - but probably not what you want.
That's probably what you want.
You could always try it on a PC ...
Do not bother.  It means either (a<b)<=c or a<(b<=c) .
It depends on the grouping (?) order of < and <=.
In the unlikely event you want either one of those,
insert the parentheses and add a comment so that others will not have to guess whether it is correct.
< is a boolean. The result is either 0 or 1. So a < b is evaluated and is either 0 or 1, then that result is used to evaluate result < c. If c is 2 or more, this will always be true. If c is 0 or less, this will always be false. Regardless of a or b in either case. As awneil says, not what you want.
EDIT:  Ah, I was working from the thread title "a<b<c" rather than the code in the OP "a<b<=c".  The outcome is similar, except w.r.t. "If c is 2 or more" which becomes "If c is 1 or more".
In Python, a< b<=c would do what OP seems to want.
It has the effect of turning n comparisons into an n+1-ary operation.
C does not do that.
Comparisons are purely binary operations that result in (int)0 or (int)1 .
What is wrong with
if ( (a < b) && (b <= c) ) {... }
ka7ehk wrote:
What is wrong with
Nothing.  The OP asked about it:
... and Andy confirmed.
Although you've added parenthesis for clarity, they aren't necessary because C operator precedence favours < and friends over &&.
ka7ehk wrote:
What is wrong with
Probably nothing,
though if b is an expression, even parenthesized, it might not work.
In languages for which a< b<=c does what OP wants,
it is more clear.
I opt for absolute certainty in execution and for clarity in mental interpretation. Why ponder over the OP's expression when you can be certain without even having to look it up? I don't have to remember the precedence rules with my expression. Win all around, as far as I can see.
Jin
I do the same and then, when I go back to it later, I never have to remember/wonder what the intention was.
MHO, real expertise comes not from knowing the precedence table, but from knowing you don't want to need to know the precedence table.
I see you've never had to maintain anyone else's code ;-)
I don't want to.  I have to.  When I clean up existing code, I do the same as everyone else here.  I add parenthesis for clarity.
But you have to start from a place of knowing the rules of the language.  Or at least knowing that there >>are<< rules, and how to find them.
C has what, seventeen levels of precedence? That's about fourteen too many, in my not so humble opinion.
I don't even rely on precedence levels for adds, takeaways, timeses, and guzintas... if you want future reviewers to understand your intentions; if you want to understand your own code by next thursday, use brackets.
Neil
When it comes to C, one basically just needs:
1. Postfix operators have higher precedence than prefix operators
2. Unary operators have higher precedence than binary operators
3. The usual mathematical rules apply, e.g. multiplication has higher precedence than addition
4. Arithmetic has higher precedence than comparisons and assignment (but bitwise have lower precedence than comparisons)
5. Comparisons have higher precedence than logic operators
6. With almost everything else: just use parentheses
Dessine-moi un mouton
