ATmega328P debugger choice
13 posts / 0 new
Hi there,
I want to debug through debugwire atmega328p device using atmel studio 7, W10.
According to the atmega328p product page the suggested debuggers are:
- Atmel ICE
- PicKit4
- MPLAB(R) Snap In-Circuit Debugger ( PG164100 )
I need to perform debug wire and programming: I would go for MPLAB(R) Snap In-Circuit Debugger ( PG164100 ).
Does MPLAB(R) Snap In-Circuit Debugger ( PG164100 ) work fine on atmenl studio 7 and W10?
I only intend to use the debugger with atmega328p.
Thank you
Regards
It works fine under me.
However, some modifications may be required.I added a pull-up resistor to mine.
I've only followed other threads on this, so I leave that to the authority.
Thank you!
I have an ISP 6 pin connector. Is there a reference that let me prepare a connection between the debugger and the ISP connector for debug wire?
I see the debugger comes with no cables
debugWire is simply a subset of the ISP pins (Gnd and _reset) so if it's wired for ISP it is wired for dW too anyway.
Atmel have a published application note about modifying Snap for use with AVRs (acutally I thought it was more of a UPDI than a DW "fix") but suggest you track that down
Thank you,
where can I find the application you are talking about?
is there an application that let me build a connector adapter between SNAP 8x1 pins and ISP 3x2 pins?
I would use SNAP both for debug wire and programming.
Thank you
Regards
Pin assignments are provided in the MPLAB PICkit 4 Debugger User's Guide.
http://ww1.microchip.com/downloa...'s_Guide_DS50002751C.pdf
Anyway, look for related materials on the manufacturer's site, read them, and try to understand them.
https://microchipdeveloper.com/search:site?q=ETN&mini=true
ETN-36
MPLAB Snap AVR Interface Modification
edit : http://ww1.microchip.com/downloads/en/DeviceDoc/ETN36_MPLAB%20Snap%20AVR%20Interface%20Modification.pdf
and more (virtual COM via USB CDC ACM)
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs?page=5#comment-2744321
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs?page=6#comment-2839061
Consider having more than one MPLAB Snap in your tool box especially when it's on sale; sometimes ... otherwise ... 404 | Microchip Technology
MPLAB Snap | AVR Freaks
wrt MPLAB PICkit 4 and PIC, the ones at Waveshare have a solution; its picture is one way to solve that issue and could be modified for AVR 6-pin.
PICkit 4 - Waveshare Wiki (top right)
Ah yes, as I thought the app note only mentions UPDI/TPI/PDI - does not actually say it's needed for dW ?
From memory,   ISP and debugWIRE work fine with or without the hardware mod.
I can "reverse" the mod if anyone is interested.
The mod is nothing more than "removing a 4k7 pulldown" and adding a 1k0 pullup.
Hello kabasan,
are you using mplab snap on atmel studio? how did you let it work?
I have this problem:
Thank you!
I posted on that thread.
I'm interesting by
How do you succeed to have it working without the mod ?
thanks for your help.
