ispEnterProgMode: Error status received: Got 0xc0, expected 0x00
16 posts / 0 new
When I used Atmel ICE programming an Atmage328p MCU, the second last step failed:
When I went to "Device Signature", this prompted:
"Failed to enter programming mode. ispEnterProgMode: Error status received: Got 0xc0, expected 0x00"
The "Target Voltage" testing was OK.
How to fix it?
Is your ISP connection correct?
Is the reset pin capacitor removed?
Is a clock supplied to the device?
Total votes: 2
Or, is the device in debugWire mode?
:: Morten
Before this prompt, there was another prompt. It said the Device Voltage was wrong, is this the reason?
This is my wiring.(in attachment)
I used the chip I have just used in Arduino IDE, so there was bootloader inside, is this the reason?
Presence of bootloader is not this  issue. It is happy to write on top of the bootloader and wipe it out.
I used PC USB port power, when I test the USB voltage, it was 5.13V, while, after I power it for Atmega328p (connected with Atmel ICE), the voltage fall to 0.14V.
and, the prompt in Atmel Studio 7.0 was:
"Read voltage -0.1V is outside selected device's operating range: 1.8 V to 5.5 V."
It's a lot more helpful if you put the pictures in your post - where we can see them:
For instructions to do that, see Tip #1 in my signature.
That's telling you that the supply voltage is -0.2V.
surprise
Clearly, the chip is not going to work at that voltage at all - and, therefore, your debugger can't connect to it!
MianQi wrote:
This is my wiring
Again:
we really can't see anything much from that at all!
please post a proper schematic (aka "circuit diagram").
Clearly, that's a problem!
Looks like you're shorting something out!
Remember that a PC USB port may only supply 100mA ...
"Read voltage -0.1V ...
That really means, "too low to measure properly" - so the -0.1V is really just noise.
There's a lot more in your photo than you've just shown there!
How, exactly, are you supplying the power to it ?
How about simplifying your breadboard to have what you've shown, and nothing else - does that work?
make the layout neat.
Note that the crystal and its capacitors need close to the chip pins, and with very short connections.
Similarly the 100nF capacitor.
If it doesn't work,  post a good, clear, in-focus, close-up photo so the we can see & check the wiring.
May well need to be more than one photo to see everything clearly.
rather than throw in all the doubts & uncertainties of breadboards & homebrew wiring, why not just use an ATmega328P XPlained Mini board:
https://www.avrfreaks.net/forum/xplained-mini-mega328pb
https://www.microchip.com/DevelopmentTools/ProductDetails/PartNO/ATMEGA328P-XMINI
That way you get known-good hardware to start learning & experimenting on ...
Thanks for you all, inspired by your suggestions, I found a solution:
Using an Arduino UNO as bridge.
But there was still an error, when I verified the Flash, there was it. While, when I didn't verify the Flash, just program, it went through.
Why? Why? Why?
In Atmel Studio 7.0
There are "program" button in "Device Programming --> Memories" and "Device Programming --> Production file".
this disturbed me half a morning.surprise
So, solution is: One should use "Program" in "Memories", not "Program" in "Production files".
The file in "Memories" is .hex format, while in "Production files" is ELF firmat.
MianQi wrote:
 I found a solution ...  Using an Arduino UNO as bridge
That is not a solution to the original problem that you posted - which was that the Target AVR had no power.
There is no way that anything could program a chip which has no power!
Somehow, you have fixed the original problem as a byproduct of re-arranging your stuff.
Mostly likely, it was a wiring problem which got correct in the course of the rearrangement.
Anyhow, if it's not solved, please mark the solution - see Tip #5 (in my signature)
