Attiny841 draws too much current during sleep mode
35 posts / 0 new
I've got the next problem with my attiny841 project. I want to use sleep mode to save battery capacity. In my test setup I've got nothing connected to the attiny841 but the TTL adapter for uart output. I'm using ATTinyCore with Arduino-Makefile for ease of use, but I'm not using much of the arduino stuff though.
The test code does nothing fancy. It sets up the sleep mode, waits a little while so I can measure current consumption during normal operation, then goes to sleep mode (10x8s). The measured current consumption is 8mA during operation and 1.1mA during sleep mode (power down mode). I'm pretty sure this is way too much.
Here's my code (reduced to the absolute minimum, I removed everything but the sleep mode stuff):
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define LED           2 //LED_BUILTIN, PORTB2
#define DELAY         5000
#define WDTREPEATS    10
void sleep_setup() {
  // define sleep mode
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  // disable analog comparator 0 and 1
  ACSR0A |= _BV(ACD0);
  ACSR1A |= _BV(ACD1);
  // unlock Watchdog configuration register
  CCP = 0xD8;
  // enable the WD interrupt, set watchdog timeout prescaler value (interrupt period)
  WDTCSR = _BV(WDIE) | (_BV(WDP0) | _BV(WDP3)); // wake up after 8s
  // change clock prescaler to 8
  CLKPR = (_BV(CLKPS0) | _BV(CLKPS1));
void sleep_enter() {
  // disable ADC
  ADCSRA &= ~(1<<ADEN);
  // wait a little for the last serial output (if any) to flush
  delay(10);
  // disable SPI
  SPCR   &= ~_BV(SPE);
  // set all bits in power reduction register to one (shutdown everything)
  PRR = 0xFF;
  // actually go to sleep
  // wake up after WDT timeout
  sleep_mode();
  // re-enable all gizmos
  PRR = 0x00;
  // wait a little
  delay(10);
  // re-enable SPI
  SPCR = (1<<SPE);
void setup() {
  DDRB  |=  (1 << LED);
  sleep_setup();
  Serial.begin(115200);
  Serial.println("init");
  delay(4000);
void loop() {
  uint8_t i;
  // light on, wait for measurement, light off
  PORTB &= ~(1 << LED);
  Serial.println("-- ACTIVE");
  delay(10000);
  PORTB |=  (1 << LED);
  // do some sleep cycles
  for(i=0; i<WDTREPEATS; i++) {
    Serial.print("----- ENTER SLEEP: ");
    Serial.println(i);
    sleep_enter();
    Serial.println("----- LEAVE SLEEP");
ISR(WDT_vect){
  // nothing to do
Does anyone have an idea what might be wrong?
Thanks in advance,
Tom
Possibly the way you are measuring it, can you post a clear picture of your setup.
Also the programmer will change your readings, remove it while measuring.
Arduino does stuff in the background (millis) with the timer, that could also interfere.
Can you post a schematic of your setup?
Keys to wealth:
If you want something you've never had...
...you must be willing to do something you've never done!
Lets go Brandon!
You can also  get sleep current through IO pins. What do you have connected? Any LEDs on while sleeping?
Do you have any potential divider across the supply - eg, for monitoring battery level ?
Don't forget leakage of capacitors. Shouldn't be a worry around the milliamp range, but can get significant when you're into microamps ...
No, I have disconnected everything. There's only Vcc and GND from batteries. The LED is off during sleep (see code above).
Schematic: https://github.com/watterott/Wattuino/blob/master/hardware/Wattuino-Nanite841_v11.pdf
Edit: fixed schematic link.
Total votes: 2
That 1k5 and Zener will draw some current.
What voltage are you getting from the batteries?
Currently 5.08V
Use a 2 cell battery and see if that helps as a test, Brian found your issue.
Keys to wealth:
Lets go Brandon!
Tomvr wrote:
Currently 5.08V
So the voltage across the 1k5 is (5.08 - 3.6) = 1.5V and the current through it is 1.5V/1k5 = 1mA. How does that compare with your excess current?
Ok, since I don't have a battery pack available I just connected the Attiny board to the lab supply with 3.3V. It now draws 435uA in sleep mode. So if I understood it right, I need to get rid of the whole board and use a 841 chip directly w/o this diode+1k5 circuit?
You could just remove the diode?
Or use a two cell AA battery pack!
Keys to wealth:
Lets go Brandon!
which would probably further reduce the current ...
As I already said, I don't have a AA battery pack available here, I'll order some online but this will take time. Meanwhile I tried it with a 3V CR2032 cell, the voltage is the same as 2xAA. Still drawing 434 uA. And I can't remove the diode, this is a board which I've ordered as it is, the schematic is not mine but from the vendor.
Tom
If you cannot remove the diode or the resistor, then you are stuck with that current drain. Seems like a design without much thought for battery operation.
So what's this, then:
So? You've got the board; you can take the diode off it - surely?
Yes, that's right.
That's a 4xAAA (triple not double A) pack which I need for other things as well. And what's the point of modifying this battery pack when I have a lab power supply? The board draws too much current whether I run it with 2xAA's or 1xCR2032 or the supply tuned to 3v.
Just to make this clear: I have this board for prototyping and doing experiments (and I think that's the intended purpose it's being designed for). I've already learned from you guys here that I can't use it in my production device. I am absolutely happy with this.
Tom
AA = 2500mA/hr
435uA draw....  lets see, that comes out to ~5747 hours, or 239 days, appx 7 months or so.
How long are you wanting your device to last on one set of batteries?
Keys to wealth:
Lets go Brandon!
ki0bk wrote:
AA = 2500mA/hr
I know (now), so I will use AA's, but that was not the question. I've just wondered why the actual Nanite draws more current than I expected.
As long as possible of course. Save the planet, you know :)
Tomvr wrote:
Ok, since I don't have a battery pack available...
So just remove two cells from your 4 pack and jumper across the two empty slots.  Voila, two cell pack!
Yes - a two cell pack of AAA's with 2.4V which is not even enough voltage to power up the board. Why are you all suggesting this?
In case anyone doesn't know... You can buy dummy batteries designed to short out the location where a regular cell should go. Useful to turn a 4-cell holder into a 3-cell one.
No need to modify anything - just take a "tap" from 2 of the cells.
It seemed you were making an issue of the fact you didn't have a 2-cell pack, and that using the lab supply was some sort of an inconvenience.
Of course it makes no difference to the current draw!
Sorry for the misunderstanding.
So, as an experiment, remove the diode - and confirm if that does give the required result!
It's not entirely clear that you're using NiCd or NiMH batteries !
Espectially as you said that 4 of them were giving  5.08V
Obviously, people are assuming primary cells to give 3V !
Eh ?
An ATtiny85 runs down to 1.8V !
ki0bk wrote:
2500mA/hr
Not mA/h - that'd be milliamps per hour.
You mean mAh - product of current & time = energy (at a given voltage).
Yes, you are correct, I must not have had enough diet coke yet when I wrote that!  Thanks for the correction.
Keys to wealth:
Lets go Brandon!
Yeah, but the board doesn't work below 2.8, I measured it.
Ok, so I tried to locate D2 and managed to remove it without destroying anything else, and repeat the measurement. Here's the result:
Tata! 19.4uA - very nice :)
Jolly good - now see Tip #5 (in my signature)
I think a key lesson from all this is that achieving low-power is not just about software - it requires very careful attention to the hardware details, too!
Indeed. I am very very grateful for the help here, really amazing. I'll also notify the vendor about this, maybe they want to modify the design.
Many Thanks!
At the least, suggest that they make the board with an easy scratch-away disconnect. Both Adafruit and Sparkfun seem to do that routinely.
Looks like it is designed for USB - so the diode is probably required for that.
When selecting hardware, it is your job to ensure that it is suitable for your intended application !
Of course, according to the datasheet it's there to protect the USB D- and D+ data lines from transients.
I know, and this thread is part of the process.
