Hi all,
I've got some 8 pin SOIC package chips in a tape. Pin 1 is not marked in any way on the chip! There is no notch on the pin 1 end, no dot molded into the part, no asymmetry to the package, nothing to indicate where pin 1 is!
I wonder if there is a "standard" which defines WHERE pin 1 is in an SOIC tape? I Googled everywhere, found lots of SOIC tape info, but nothing that seems to indicate any pin location standard.
And, of course the datasheet for the chip does not indicate pin 1 either. The datasheet shows a line of some sort molded into the package, but there is no line on the actual chip.
Please see attached images.
(click thumbs for full size)
Any info will be appreciated!
