AVR Dragon
4 posts / 0 new
One of these should be in everyone's AVR toolkit. Sad to see Microchip Atmel discontinue it. Such a useful piece...especially for unbricking misconfigured fuse settings that prevent ISP access. Most useful for production batch programming as well.
I just recently added the HV Parallel Programming header, the device pin header, and the 40 pin ZIF socket to mine. I had accidentally bricked a SOIC-20 ATtiny26, and with an SOIC adapter I was able to successfully rewrite the fuses with it, allowing ISP access once again.
Especially useful for presetting fuses and pre-flashing the Optiboot bootloader for devices being installed into an Arduino.
Wish I knew where to pick these up from on the used market. Would love to grab a few just to have on hand in case one fails.
Jon Wilder
Freelance Embedded Engineer
Jon,
If you are concerned with your Dragon's longevity, you should build a Dragon Lair (http://www.aplomb.nl/TechStuff/Dragon/Dragon.html ) . A schematic is about half-way down the page.  It isolates the target micro controller from the Dragon's output.
Alan
It's not a matter of if, but when it fails.....
I'm using one for production programming now, with one spare left, I have two broken ones, I hope to fix some day.
or EOL distributor
AVR Dragon availability | AVR Freaks
