Find/Post your Online C Books & Tools here ....
60 posts / 0 new
Pages
Wikibooks, open books for an open world
C Programming
https://en.wikibooks.org/wiki/C_Programming
A comprehensive look at the C programming language and its features.
Level : All
Sonos wrote:
Embedded C Programming and the Atmel AVR
by Richard H. Barnett, Sarah A. Cox, Larry D. O'Cull
Category: AVR Embedded C; CodevisionAVR compiler specific
Level: beginner/intermediate
was republished in 2011, in paperback and Kindle ebook, and is one of three two AVR books at Cengage Learning :
http://www.cengage.com/s?q=AVR&searchbtn=Search
was :
http://www.cengage.com/search/showresults.do?N=16&Ntk=APG&Ntt=AVR&Ntx=mode+matchallpartial&Nr=16
Edit : strikethrough, was
A review of the C11 standard :
Embedded
Why you need the C Standard
by
October 27, 2014
http://www.embedded.com/electronics-blogs/break-points/4436489/Why-you-need-the-C-Standard
But it is full of gems that the more accessible C books seem to miss.
The C11 standard devotes a full page to assert() and show it used in examples in other locations.
Appendix F is a must-read for all developers. It’s hard to get floating point math right.
Appendix C lists sequence points, ...
Various web sites make it available, at least in pre-final versions, ...
ISO/IEC JTC1/SC22/WG14 - C
http://www.open-std.org/JTC1/SC22/WG14/
ISO/IEC   JTC1/SC22/WG14 is the international standardization working group for the programming language C.
Howdy Freaks,
One of the best way to learn C programming language is through Learnbix.com
Following are some advantages to learn here:
  1. You can learn C from basics to advanced concepts
  2. You have different questions and quizzes to solve
  3. Print and PDF options are available
  4. All topics are briefly illustrated with good examples
Prasad
@spscp So is this your own site? Or are you in some way affiliated to it?
Please be clear & honest.
But it doesn't seem to be working at the moment:
spscp wrote:
 Learnbix.com
Andy he posted in FEBRUARY! The only reason this thread surfaced now is that there was spam that I deleted. Let it rest.
Aaagh - the deleted spam leaving the thread flagged as 'New Activity' again!
blush
His/her "best way to learn" site didn't last very long, then - did it?
EDIT
On the "known issue" of deleted spam leaving threads flagged as "new": https://www.avrfreaks.net/comment... - the "workaround" is no longer being applied?
My phone pushes things to me it thinks I might be interested in. It sent me a link to this beginners guide to C:
https://www.freecodecamp.org/news/the-c-beginners-handbook/
It looks "chatty" so may be of use to some ?
Thanks for sharing this information
I am a software engineer and currently I am working on my education online  portal  Java Vogue . This blog provides  tutorials for java , spring , hibernate , MySQL , Cassandra , spring boot , sql , react , angularjs etc.
Pages
