VCC and GND shorted on a module device. Static?
14 posts / 0 new
Hi All
I was preparing a PCB by soldering the components . There is a LGA module which i also manged soldered.
Before powering the PCB, i always check that the VCC and GND are no shorts.
On this particular PCB i noticed the VCC and GND was shorted.
Therefore i removed the LGA module to check the PAD below it.
After some investigation i found the VCC on the actual module is shorted to GND, but there is nothing on the pads. It seems like it something internal.
Has anyone else experience such issue similar to mine? This is first time this has happened.
Can static do similar issues?
Regards
DJ
No, it was not static, (or at least is extremely unlikely).  MUCH more likely is you measured with the meter polarity reversed.
What happens when you measure another one of these modules?
Are you sure of which "pin" is which?  Part flipping and rotation can make you very dizzy.
Depends on what you determine to be 'shorted'. There is very low resistance (< 1ohm) and high resistance (> 1 Ohm). Measuring this can give an insight in the kind of short circuit and maybe the likely cause. Usually very low Ohm shorts are soldering, pcb etch problems or maybe a capacitor. Static damage usually causes a more resistive problem.
Warning: Poor joke ahead!
Is that meant to be "mangled" or "managed"?
When we measure other boards, the resistance is is few hundred ohms.  While on this board it is 0 ohms,
When the module is flipped i am sure it is the right pins.
Regards
DJ
Maybe its faulty module to begin with.
Regards
DJ
It's more likely you damaged the module during soldering or desoldering...trashcan it & see if it happens again.
Is your soldering machinery operating under a verified process?
I am using hot air and hot plate re work station from Aoyue. Maybe i could have applied hot air onto the board or near by components much longer then i should have.
Regards
DJ
For parts like that, you should probably be using an actual multizone reflow oven, with a tightly controlled temperature profile.  This is not an 0805 resistor!
I know, i wanted to check my design was working before paying for some boards to be assembled by another company.
Are there any small scale ovens  for prototypes that are recommended?
Regards
DJ
A lot of people build their own
I know of several people who have built the controleo oven.  In fact, i have a kit , but haven't built it yet
   https://sites.google.com/site/markscontroleo2build/
https://whizoo.com/reflowoven
Of course, if you have the $$$ just buy an oven
LGA's are not soldered, but rather are placed into a socket???
BGA'a are soldered!  And very difficult to do by hand!
This the LGA that is being used:
https://www.quectel.com/product/bg96.htm
Regards
DJ
you have not accidentally crossed the probes and are now measuring the protection diodes right?
i would not expect a module like that to already be a fail out of the box. So something has happened.
you could have indeed overheated it.
