Hi
I am working on a PCB and will need to get a stencil made.
I have been advised that on components such as QFN with a GND pad , that i should create small squares or circle, so that paste does not cover the entire pad.
What layer would i need to modify the component this on as i can see a "Top Paste" and "Top Solder"
Should the solder paste cover the entire pad of a component all the components such as passives?
I am using a old version Altium designer
