Creating PCBs Help
7 posts / 0 new
Hi guys, I'm trying to make my first PCB using the toner transfer method but I'm not having any luck.
I suspect that it is due to my iron not being hot enough. Does anyone have a measurement of how hot the iron should get?
-- Equipment used --
I'm using stables glossy photo paper, and a HP Photosmart 8250 printer.
After 10 min of pressure and heat I start to see ink bleeding though the back of the photo paper BUT it still doesn't stick to the copper clad board. I am getting enough heat however to melt the glue off the double sided carpet tape that I am using around the edge.
I'm using the following kit for the board and chemicals.
http://www.thesourcecc.com/estore/product.aspx?language=en-CA&product=2761576&category=PC+board%2fSockets&catalog=Online&tab=1#more
I'm not a cartoon character but I play one in real life.
Not too long ago I started too with home-brewing of PCB's.
Here's the thread: https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=44698&highlight=
Nard
HP Photosmart 8250 is a ink printer. You need a laser printer for the toner transfer method.
I just bought a HP1018 laser printer at Microcenter for $65! (regularly $130 with a $65 mail in rebate) I bought it specifically for doing PCBs this way. I got tired of running to the office to make my transfers.
Mike.
official AVR Consultant
www.veruslogic.com
Nard
Ever have one of those days were you can have the answer to every problem anyone can come up with, only to have people point out you completely missed the obvious :roll:
Mike.
I just got one too :wink:
I should know how well it works in a few min :D
You must be from canada as the source is a canadian company.
I use staples picture paper works pretty well and it is cheap. If you are in toronto you can pickup a cheap copper boards at supremetronic and some etching solution from them, I think the name of the etching solution I use is feric-chloride (it is feric-something).
toalan wrote:
Thanks for the info, yes I am from Canada. Funny enough I love close enough to Toronto to see its light pollution but far enough to not smell its air pollution :? .
I'll be in the city next week so I'm going to make a stop by supermetronic.
To answer you next question. I hate the Leafs but love the Argos.
