SPI and optimization?
12 posts / 0 new
Greetings freaks -
This is really a mixed question about optimization and AVR SPI operation.
Environment: AS7 in Windows 10, ATmega328P
I use the SPIF bit in the SPSR (SPI Status Register) to detect when a byte transfer is complete. No interrupts are used. The spec sheet does not indicate any method for clearing the SPIF other than reading the SPDR (SPI Data Register) or responding to an interrupt.
Now, I have come to the point where i need to read a bunch of bytes to empty them in the peripheral, discarding the results. I set up a local variable to do the read, but it is optimized away (presumably since the variable is never used), leading to no SPDR read and no reset of SPIF. I know that I could set up a global volatile variable, but that seems to be a waste for something that is really a local variable with a temporary life.
So, how can I insure that this read takes place?
The most you should have to do is:
SPDR;
This will force a read and discard the results as the definition of SPDR contains 'volatile'.
Hmm, did not realize you could  do that.
Does that not generate a warning like "statement with no effect" or somesuch ?
Something isn't quite right. Show minimal test case. SPDR is/should be volatile. Any access, even if not stored due to optimizer, should still be generated.
You gurus with better memories can comment on the GCC reordering possibility.
Hmmm, I thought it was being optimized out,  but when I retried, it all seemed OK.
Sorry for the noise!
Small nitpick - ‘insure’ and ‘ensure’. Insure is your plan B when the worst happens, ensure is to put things in place so it doesn’t happen.
Bottom line is there will have been IN Rn, SPSR. Sure Rn may not have been used any further but the IN will have been in the LSS
Kartman -
But, of course!
No because it does have an effect.  It forces an IN instruction to be emitted by the compiler.  If anything, one would think it would complain about the result being discarded but the C compiler in GCC doesn't.  I'm not a C standards guru so I don't know if this is expected or not.
Ganssle makes that transposition often.  Makes me crazy ;-)
Kartman wrote:
Small nitpick - ‘insure’ and ‘ensure’. Insure is ...
... Flo.
Kartman wrote:
, ensure is ...
