JTAGICE3 will program, but not debug
6 posts / 0 new
I am trying to debug a program on an XMEGA-A3BU Xplained board using the AVR JTAGICE3 programmer/debugger.  I can program the device fine, but when I try to Start Debugging and Break, I get a pop-up window "Failed to launch program. Error: Invalid daisy chain configuration.  Debugger command Activate physical failed.
Tool Information:
JTAGICE3
Debug host        127.0.0.1
Debug port        58518
Serial number     J30200031068
Connection        com.atmel.avrdbg.connection.cmsis-dap
Features          1
Firmware Version  3.37
Hardware Version  2
Device Information:
Detected device
Device names      ATxmega256A3B, ATxmega256A3BU
Device signature  0x1E9843
JTAG id           0x6984303F
Revision          G
Datasheet information:
                              ATxmega256A3BU-AU      ATxmega256A3BU-MH
CPU                                        AVR8_XMEGA
Flash size                         264 KB (256 KB+8 KB BOOT)
EEPROM size                                   4 KB
SRAM size                                    16 KB
VCC range                        1.6 - 3.6 V            1.6 - 3.6 V
Maximum operating speed            32 MHz                 32 MHz
Fuses:
JTAGUSERID = 0x00
WDWP = 8CLK
WDP = 8CLK
BOOTRST = BOOTLDR
TOSCSEL = XTAL
BODPD = DISABLED
RSTDISBL = [ ]
SUT = 0MS
WDLOCK = [ ]
JTAGEN = [X]
BODACT = CONTINUOUS
EESAVE = [ ]
BODLVL = 1V6
FUSEBYTE0 = 0x00 (valid)
FUSEBYTE1 = 0x00 (valid)
FUSEBYTE2 = 0xBF (valid)
FUSEBYTE4 = 0xFE (valid)
FUSEBYTE5 = 0xEF (valid)
Lock Bits:
BLBB = NOLOCK
BLBA = NOLOCK
BLBAT = NOLOCK
LB = NOLOCK
LOCKBITS = 0xFF (valid)
Can't figure this one out.  In addition, in the Tools, Device Programming window, the Interface settings has a box "JTAG Daisy chain settings" I had to check the box Target device is part of a JTAG daisy chain, and the Detect Devices Now sowed a description of "Device/TAP with ID 0x6984303F" with an IR Length of 4. I assume the ID represents the XMEGA-A3BU board, but what is this IR Length of 4?
Any assistance with getting the debug working would be greatly appreciated.
Fred
Just turn off daisy chaining (Select 'Target device is not part of a JTAG daisy chain'); https://www.microchip.com/webdoc...
:: Morten
Thanks for the tip.  However, I am still not able to debug my program. "Faied to launch program. Error: Invaled daisy chain configuration.  Debugger command Activate physical failed.
Thanks for looking,
Fred
When I tried the "Attach to Target" button, I get the same error window as in the above posting. The JTAGICE3 does recognize the device, and I am able to program the Xplained board with the JTAGICE3, but I am not able to attach to the device or debug the program running on the device. Thanks, Fred
I am revisiting this project after a few years.  I used to be able to program and debug this project (assembler) with the JTAGICE3, now debugging is not working. I did upgrade the Atmel Studio 7 to the latest download a few days ago, but this did not address the inability to debug. I have ordered the Atmel-ICE Debugger and Programmer Full Kit , thinking that somehow the JTAGICE3 is broken. The Atmel-ICE will arrive tomorrow. I should have an update tomorrow evening on whether this will allow debugging.
Fred
The Atmel ICE arrived last night.  Happy to report the ICE is able to debug the program successfully.
Fred
