Configuration Change Protection (CCP)
5 posts / 0 new
Is this how to write to protected I/O registers?  Is it ok to write to the CCP register again before the 4 clock cycles have elapsed?
Main: ldi         Temp2,0xD8               ;Load Temp2 with the unprotect code.
        sts        CPU_CCP,Temp2         ;Disable I/O write protection.
        ldi         Temp1,0b00000010     ;External 32kHz oscillator.
        sts        CLKCTRL_MCLKCTRLA,Temp1
        ldi         Temp1,0b00000000     ;No prescale on the 32kHz clock.
        sts        CLKCTRL_MCLKCTRLB,Temp1
        ldi         Temp1,0b00000011     ;Enable clock always. 30 msec clock startup time.
        sts        CLKCTRL_XOSC32KCTRLA,Temp1
Do the LDIs first then two consecutive STS just to be sure. Oh and depending on context you might want to consider the possibility of being interrupted.
The "key" write to the CPU_CCP and the write to the controlled access register must be within a very small number (4?) cpu clock cycles. Looks to me like there are hardly any alternatives to what you are doing in assembler except what Cliff describes. I would define TampA, TempB, and TempC, preload those before hand, then to the key write, immediately followed by the register write. OR, maybe, saving some registers,
By the way, this is the  listing you get when you click the "<>" icon up in the toolbar.
Thanks.
The Attiny817 data sheet says:
Now this is for the tiny817 so I imagine other chips could be different.  Is that what you meant by context?
