ATTiny 4313 UART as SPI
4 posts / 0 new
Look out! It's me again
I'm trying to use the UART for SPI.
DO is Port D 1
DI is Port D 0
XCK is PORT D 2
But I don't think my uart init is right as I don't get any clock signal when I try to write 0xAA repetedly.
void SpiSetup()
	  DDRD |= (1<<1); // as output (DO)
	  DDRD |= (1<<2); // as output (USISCK)
	  DDRD &= ~(1<<0); // as input (DI)
	  UCSRB = (1<<RXEN)|(1<<TXEN);
	  UCSRC = (1<<UCSZ1)|(1<<UCSZ0);
	  UBRRL = 0; // go fast on 1MHz clock
	  UBRRH = 0;
uint8_t SpiTransfer( uint8_t B)
	while( (UCSRA & (1<<UDRE)) == 0) ;
	UDR = B ;
	while( (UCSRA & (1<<RXC)) == 0) ;
	return UDR ;
(I've always used the SPI peripheral before.)
USART in MSPI mode should use RXD/TXD/XCK signals on PD0, PD1, PA0.
You have set the UCSZ bits for 8-N-1 UART.   You should set the UMSEL bits for MSPI.  e.g.
void spi_config(unsigned char master, unsigned char mode, unsigned char speed)
    PORTB |= (1<<SS);     // pull-up i.e. disabled
    DDRB |= (1<<SS);
    UBRR0 = 0;
    XCK0_DDR |= (1<<XCK0);
    UCSR0C = (3<<UMSEL00)|mode;
    UCSR0B = (1<<RXEN0)|(1<<TXEN0);
    UBRR0 = speed;
You probably use mode#0 and speed=0 i.e. F_CPU/2 which gives you 8MHz SPI on a 16MHz tiny4313
XCK is on PD2 for tiny2313A, 4313
You can choose any GPIO pin for CS.   (my naming SS is inappropriate since MSPI can never be a Slave)
USART_MSPI mode has been available on Mega328, 324 family chips ever since they were born.
USART_MSPI mode only appeared with Tiny2313A (and Tiny4313).   It was never on Tiny2313.
David wins the kewpie doll! Now I see the signals.
Thanks, guys. I was getting myself all in a tizzy over that.
(The example in the PDF doesn't seem to match the .h file's names.)
