Compiler question
14 posts / 0 new
Guys when I build a C++ program it works if I have not included libc.a…  However functions such as printf don't work.  If I include libc then printf ect work bt c++ runtime such as templates, exceptions and lists fail.
Please guys, has anyone a suggestion?
Can the functionality of the I/O functions in the C code be moved to C++?
(in-lieu of, C++ streams?)
This statement doesn't make much sense. You need to explain it better. What "fails" specifically and how? Fails to compile? Fails to link? Fails to run?
The patient says, "Doctor, it hurts when I do this." "Then don't do that!"
my projects: https://github.com/epccs
Debugging is harder than programming - don’t write code you can’t debug! https://www.avrfreaks.net/forum/help-it-doesnt-work
The system seems to hang when an interrupt occurs.   I would really need to run the debugger to find out more but the problem is likely to be a linker flag to the c/c++ telling it not to do something.
Does your combination of libraries have a working malloc() ?
IIRC, the newlib printf() does use malloc() (perhaps even the C++ and C malloc() functions are not compatible?)
(Just grasping at straws.  printf() essentially works fine on Arduinos, which are C++ combined with C...) (once you add the hook for actual IO)
Interesting, I tested malloc and it works.  I'll run the debugger tomorrow and see if it sheds anymore light on the matter.  If I was to guess though I would bet my het that it is some weird c/c++ flag required for the linker.  See here... https://gcc.gnu.org/onlinedocs/gcc/Option-Summary.html
Can you release the files you have?
You're trying to get the ASF C "libraries" callable from C++ projects in AS7, for ARM, right?
I'm sure it's swell that Arduino printf() works, but it doesn't use either Studio or ASF, so for all I know it's a completely different problem.
Hi westfw, it is apart of the Atmel software package 2.15.  I've edited four make files to get C++ working.  In bed here at the moment so I'll not know more until tomorrow.  I going to test it on a example project to rule out the kernel my system is running on.
PS: I'm using DS-5 eclipse...
When I look at your link, it mentions SAM9  So it appears to me that OP is up to his/her old tricks and putting ARM questions into the AVR area, and y'all are again encouraging this by solving problems.  As a guess that is why no simple test program was posted.
Its a compiler question. indecision
And here it resides:
Welcome to the Compilers, Assembers, Linkers and General Programming forum for ARM-related discussions
Posted by Michael@Atmel on Wednesday, 30 September 2015 - 14:25
Just to clarify, I tested the system and it hangs when an interrupt occurs after calling certain c++ functions such as exceptions.
I tested this with the following piece of code:
	start_heartbeat();
	for(int i = 0; i < 20; i++){
		msleep(1000); led_toggle(0);
	templates();
	classes();
	virtual_func();
	name_space_test();
	lists();
	exceptions();
	while(1);
start heart beat, starts a timer interrupt. The system fails when the interrupt occurs after calling a c++ function.
Strange!
