[SOLVED] Atmega128A external interrupt problem - resets main
6 posts / 0 new
Hi everyone,
I'm trying to catch an external input,
Atmega128A - PE4 is connected to 5V with a pullup resistor, whenever I change the state of PE4 (INT4) to 0. It resets itself.
I spent whole evening but cannot solve the problem , pls help me,
I added the other ISRs(INTXXX_vect) { } just to be sure that I catch my Interrupt.
I also tried to assign EICRB  to 0,1,2 and 3 nothing changes.
Thanks a lot.
#define F_CPU 8000000
#include <util/delay.h>
#include <avr/interrupt.h>
ISR(INT0_vect) { }
ISR(INT1_vect) { }
ISR(INT2_vect) { }
ISR(INT3_vect) { }
ISR(INT4_vect) {
	PORTA ^= (3<<0);
ISR(INT5_vect) { }
ISR(INT6_vect) { }
ISR(INT7_vect) { }
int main (void)
	EIMSK = (1 << INT4); /* enable INT4 */
	EICRB = 0; /* trigger when it changes */
	DDRA = 0b00000011;
	sei();
	for(;;){
		PORTA ^= (3<<0);
		_delay_ms(500);
Uncheck the M103 fuse?
The comment on EICRB = 0; /* trigger when it changes */ is incorrect.
Thank you  ka7ehk  It is solved!
I tried it  before I leave from home in the morning :)
I made some research about M103
Any software you write with the ATmega128 in in mind is 99% guaranteed to fail if you attempt to run it while the chip is in M103 compatibility mode... you'll have to at least modify that fuse.
You saved my whole day from thinking of it :)
boraciner wrote:
It is solved!
Excellent!
Now see Tip #5 (in my signature, below; may not be visible on mobile) for how to properly mark the issue as resolved.
Thank you, I did it ;)
