Default F_CPU for "ATmega4809 Xplained Pro"?
11 posts / 0 new
If this is just a matter of RTFM, then I apologize for not having read every word of the manual, because I have not. But, seems to me that this warrants at least some word in the Xplained Pro manual. I read it very carefully and searched for both "F_CPU" and "MHz", turning up no hits.
So, can some kind soul enlighten me about F_CPU? AFAIK, I have not touched any fuses and have never invoked START onto this board.
Really, all I want to do is test some TWI code, but you have to set the bit rate to do that!
megaAVR 0-series have two CPU frequencies due to the wide VDD range (Safe Operating Area or SOA)
Getting started ATtiny 1 & 0 series / Application Notes | AVR Freaks
TWI attachment, file I2C.h, line 57 has 20MHz
Guess that I'll just have to "hack it". Or RTFM.
Disclaimer:  I've not worked with the O-series yet.
I think the default is the internal 20 MHz Osc with the Div by 6 fuse enabled, for a startup of 3.333 MHz.
(Yes, that is /6, not /8)
I'd run your blink the LED at 1 Hz test assuming the above and see if it works.
Edit: Typo
Thanks JC.
If it helps, my 4809 Curiosity Nano (see recent post) runs at 20MHz.
But as JC says they power on with a default /6 so usually the first thing you have to do in code is a CCP protected write to clear the /6 if you really want 20MHz rather than 3.3333MHz.
OK, so I need to look at actual fuse values.
this link has some info about that protected write
https://www.avrfreaks.net/forum/tutsoft-avr-01-series-setting-tca0-split-mode-pwm
_PROTECTED_WRITE(CLKCTRL.MCLKCTRLB, CLKCTRL_PDIV_1X_gc | CLKCTRL_PEN_bm);
Correction, I guess... (improper terminology) in case someone stumbles on this:
1. The clock prescale value is not a fuse setting, unlike M328, but is in CLKCTRL.MCLKCTRLB
2. The initial choice of 16MHz or 20MHz IS a fuse setting OSCCFG fuse
3. As implied in Ron's msg #9, CLKCTRL.MCLKCTRLB has write protection.
You have only 2 possible speeds out of reset - 3.33MHz/2.66MHz, depending on what OSCCFG.FREQSEL fuse it set to, which has already been said (9.3.3 Main Clock After Reset). You cannot muck up the clock system, and it appears the only time you have the potential for problems is if you successfully switched to an ext clock (as main clock) and then lose the ext clock, which then requires a reset (wdt).
One thing to watch out for- Vdd vs freq (info is in another datasheet for the mega4809). For example, if you want to run at 3.3v, then your max becomes 10MHz. Its probably an easy thing to overlook and probably a hard thing to figure out when it causes problems.
