Digital Audio Sinewave Generator, a project draft
58 posts / 0 new
Lately, I needed to build an audio sinewave generator to produce, as a first step, 30 frequencies around the ones listed below (18 KHz to 615 Hz):
18,000
15,500
13,500
12,000
10,800
 9,800
 9,000
 7,700
 6,760
 6,000
 5,400
 4,900
 4,500
 3,850
 3,380
 3,000
 2,700
 2,450
 2,250
 1,930
 1,690
 1,500
 1,350
 1,230
 1,130
   965
   845
   750
   675
   615
The exact frequency values are not important as long they are close (tolerance +/- 0.5%) to the ones listed above.
I have to use ATmega8L only with an external 8 MHz crystal, and some general purpose resistors and capacitors.
But, with these limited components, I also have to satisfy the following conditions:
[1] The 30 signals have just one passive RC filter.
[2] Their output amplitudes could be at any level as long they are close to each other (tolerance +/- 5%).
[3] Their distortions (THD) have to be less than 1% (audio) and less than 2% (total).
My question is:
Do you think that the saying “necessity is the mother of invention” could be applied in this case too?
Thank you.
Kerim
I’d use dds and a switched capacitor filter.
If there were no constraints, then why would you need an engineer!
And if I live elsewhere I would use one of the digital sinewave generator ICs smiley
Which probably use dds and switched capacitor techniques.......
I think so, too
That’s not to say you couldn’t use a wien bridge oscillator then freq and amplitude lock by switching capacitors and/or resistors.
Or a permeability tuned oscillator or .......
I guess you mean certain analogue solutions by using active devices other than ATmega8L.
I look for a digital generator so that, when the project is done, the frequency values are fixed and known.
And once the MCU (here ATmega8L) gets the index number of the frequency (from 0 to 29 as a first step), it generates the requested signal. This request could be done by manual switches (5 now) or via TWI connection from another MCU.
KerimF wrote:
...as a first step...
So will the specification change in future if this is just the first step?
KerimF wrote:
I have to use ATmega8L only...
So no other chips allowed?
So just one R and one C?
I meant by "as a first step" just the number of frequencies. 30 is actually the minimum number in this upper audio bandwidth. (Added: I mean, it could be increased in the future).
Yes, the active device of the generator is ATmega8L only... which I can get smiley
About the passive RC filter, any number of Rs and Cs could be used.
Its been too many years ago since I did all of the FFT calculations to "prove" it, but from experience I doubt you will be able to meet those spec's.
The issue is that a DDS is likely the "best" way to generate the broad range of frequencies you need.
It will generate an output sine wave with a fixed, constant amplitude.
To meet your distortion requirements you need a pretty good LPF on the DDS output to remove the higher frequency harmonics embedded within the signal.
The DDS output is a series of small stair-steps, and those sharp cornered stair steps contain lots of high frequency harmonics and energy.
The filter will easily remove those and give you a very clean sine wave.
The problem is that the "passive RC" filter's transfer function is a function of frequency.
It isn't a perfect LPF.
As the input signal goes up in frequency, the filter will cause greater attenuation of the desired signal as well as attenuating the harmonics.
So the amplitude won't be constant across the full frequency range.
The next concern is that the output likely has to drive something, or else why build the device at all.
The device you connect the RC filter too can "load" the filter, and change its characteristics.
That is why one would typically have an op-amp to provide the final output signal, and isolate the load from the signal generator.
So, if you have an op-amp available then why not use it for the LPF?
(You stated the spec is only a passive RC filter).
If you had a twin op-amp package it would be easy to have a 4th order LPF and have the op-amp (filter) drive the output.
It will still be a challenging spec as the harmonics for the 600 Hz signal are in the region of the 1800 Hz signal.
That is what a switched cap filter was mentioned above, but that is a far from passive device!
If you go the DDS route, then the higher the micro's clock the "better" the original sine wave that is produced by the micro.
So using 16 MHz would be a better option, if you can include an Xtal in the design.
If you want any form of accuracy for the frequency you likely want to use an Xtal and not the internal RC Osc anyway.
You also need to think about how you will actually generate the output signal.
The audio guys have a nice rule-of-thumb for how many bits in an R-2R resistor ladder one needs for a given distortion.
Using an R-2R ladder for the output requires very well matched resistors to meet your distortion requirements.
(Both the number of steps, and how well the steps are matched, impact the output signal).
If you don't want to use the R-2R for the output then you can use a PWM output to generate the output signal.
Of course if you had an Xmega available you would have a 32 MHz (in spec, or low 40's MHz overclocked) micro with an internal DAC module.
So the signal generation becomes much easier.
Your filter requirements, however, still make this a challenging project.
Edit: Typo
This is one of my favorite photos, I've posted it a time or two before, but it is relevant to this discussion as well.
The top signal is a DDS "sine wave", generated with very few steps.
It is obviously a pretty crude sine wave at best.
Feed it through a two stage op-amp LPF and you get the bottom signal.
The harmonics are gone, and one gets just the fundamental frequency, and a nice looking sine wave.
Hi JC,
First, I like to thank you for the interesting analysis of the subject.
Second, you are totally right. Using DDS, R-2R ladder or PWM cannot help in this case. And, as you said, the output of the passive RC filter should be buffered. Actually, it will be followed by one (or two opamps) in order to control the end amplitude from 0V to Vmax (but this is another story smiley ).
So I had no choice but to think out of the box to fulfil the three conditions above.
After days of work (since here 6/24 of electricity only and no enough fuel to warm the room in which I work), I was able generating all 30 frequencies with rather very low THD  (condition 3). The signals at the output of the simple RC filter (condition 1) are like the sinewave on your scope (#11). I am trying now to decrease, as possible, the difference among the generated sinewave amplitudes since it is now around +/- 20% (not +/- 5%).
I have no doubt that if you found yourself facing the same conditions, you would surely think of the solution the way I did.
Kerim
I would try using one of the PWM outputs on timer1, feed it a sine wave table value and filter with a simple RC filter, since the spec in the OP says output amplitude is not important,
you may get away with a single RC low pass filter for most of the range, experiment with values of R and C.
I would start with 10k and 100nf, see what you come up with to meet the low end distortion value and how low the signal will be at the high end.
Adjust R and C as needed, this is probably what your teacher wants you to learn.
I can provide example code to get you started.
FF = PI > S.E.T
My teacher?! PWM?! Aren't you kidding, Jim laugh
But perhaps this is the first time you heard of me cheeky
If you are serious, you will real surprise me if you do think that, by using PWM (of ATmega8L), one can generate very low THD sinewaves for 18 kHz and 615 Hz (the two limits on the OP list) by using just one passive RC low-pass filter (of any degree).
By the way, this project is about the main part of one of my future products.
Kerim
Added: Please note the condition 2, on OP, concerning the output amplitudes.
Sounds like you are getting close.
If your LPF is skewing the amplitude, one solution could be to use a 8/12b R-2R DAC, where the highest frequencies use 8b for speed, and at some middle value,  you switch to 12b, which greatly improves the distortion of the lowest Hz
That then relaxes the LPF somewhat.
Or, you may find expanding the table is enough, with 256 steps in Y axis, you can usefully have 1024 LUT entries and those will all be used below ~ 868 Hz
Your suggestions are good, Wh0-me.
But the "necessity" here is that, besides the passive RC filter, there are ATmega8L and 8 MHz crystal only... nothing else smiley
By the way, I tend to believe that the idea (I got while dreaming in bed smiley ) of the method\routine which made possible to build this digital audio sinewave generator with the OP constraints cannot be found on any website. The reason is simple; its seems no one in the world, but I, needed it in the first place angel
Your OP was this
So the R-2R is certainly made from  'some general purpose resistors' - the point is the finer the steps, the easier the filter's task.
You may also be able to use port pins as CMOS switches, to change the LPF caps.
Yes, your two points are valid indeed.
But it happens that my routine/code lets just one passive RC filter do its job properly; by giving a low THD sinewave output for all frequencies on the list.
And this fact should be considered as an interesting hint to guess the routine/code which I had the chance to think of.
Just me being curious.....
Is this a one off project for yourself or mass market?
JIm
Kerim, if you like interesting ways to generate sine waves, have you read any of Don Lancaster's work?
Search terms are "magic sinewaves" "step-locked sinewaves" "walking ring sinewaves".
Hi JIm,
As I mentioned earlier, I needed to build this rather simple generator (which will be made to cover the audio bandwidth, from 20 Hz to 20 KHz) for one of my future products.
But implementing it properly (to satisfy certain conditions) takes many days of work, in my case, since the only tools, I have, for my calculations are excel and LTspice.
Kerim
Brian, so you know already how an ATmega8L and a simple passive RC filter can generate sinewaves from 615b Hz up to 18 KHz with low THD (at any frequency) cheeky
I will upload my work, when finished, as a project in memory of ATMEL; the last American company that didn’t have to close its door every time I knocked on it, for more than 25 years.
From this project, you will also deduce that its technique can be used to generate hundreds (if not thousands) sinewaves of frequencies between 615 Hz and 18 KHz with the same RC filter (same R & C values).
In the same way, it is possible to generate sinewaves in the lower audio spectrum (20 Hz to 600 Hz) but by using an MCU pin to switch on a few capacitors into the previous RC filter (via NPN transistors for example) for these lower frequencies.
And I believe that many engineers around the world will exploit its technique to also generate ultrasonic and subsonic frequencies by making minor changes and/or additions.
So till the time when I will upload this project, I think the “necessity” to many friends here is, now, to surprise me... by their discovery of what I did.
Have fun.
Cheers,
Kerim
Keri,
Check your PM.
Sorry Jim, it seems you forgot that I can access the forums only sad
I don't understand, you cannot read Private Messages?
Yes, I can't read any PM... and even I can't update my profile. In other words, when I try accessing other than the AVR forums I just get a blank page... till I feel bored and close it smiley
Kerim,
Would this work if you had them:
https://www.sparkfun.com/datashe...
Thank you, Jim, for reminding me the analogue IC (XR2206) by which I built, about 40 years ago, the first two signal generators for my various tests (both are still working smiley ).
But now, using a digital generator is crucial for my future product. Frequencies should be fixed and known.
IC, (Pun intended)
I was going to send you some if you wanted them, but I guess theres no need.
CHEERIO!
Thank you, Jim, for your personal care.
By the way, if I was able to get anything from abroad (paid or gifts) in these days, I wouldn't have the necessity to dream of a new technique to build a simple low-cost digital sinewave generator with what the local retailers can offer me as electronic components. smiley
KerimF wrote:
...what the local retailers can offer me as electronic components.
I am genuinely interested in what sort of components you are able to get, both from local stores (do you have those?) and via the mail. And what sort of prices you have to pay.
Here in the UK we have lost nearly all our local electronics stores. I think I would struggle to find more than 6 in the whole of the UK who could sell me a 2k7 1% resistor over the counter.
On the other hand we are spoilt for choice with online sellers. I regularly deal with 4 or 5 UK based companies who will have components on my desk by 11am even if I order at 7pm the previous night. And if I'm in a real hurry I am less than an hours drive from RS Components' main office.
Not that there were ever many!
indeed.
Is that the round trip, or each way?
For me, it's about an hour each way to the nearest RS trade counter.
factoring-in my time and the mileage cost, it'd probably be cheaper to pay for their express courier delivery.
unless I happen to be going that way anyhow ...
In Cambridge we had the Aladdin's cave that was H Gees. But in general we do seem to have done poorly in comparison to some places.
44.1 miles is my shortest route according to Google.
I've been there twice when it was the only option to get something out of the door.
But generally I just use online suppliers. An order from Rapid is usually delivered around 9:30, Farnell around 11:00, CPC around 11:00 if I pay the £2.99 upgrade, and RS towards 16:00.
Life here after March 2011 is almost the inverse of life we have had before that date (likely by a supernatural decision smiley , our paradise was transformed to hell).
Before 2011, it was enough for me to design and draw the necessary schematics (using Kicad) for a new product and send them to a Chinese company. There, the Chinese engineers draw for me the PCB layouts so that they could produce and test the assembled boards before sending them to me. Obviously, they got all components from China while we agreed to use genuine ones only by paying them a higher price.
After 2011, the ordinary people (as I) who are living here have been isolated, step by step and year after year, economically by decisions made by certain world's Elite (besides terrorism). So many local people (in millions) had to flee while I stayed home. I mean; one just needs to imagine how people lived their World Wars 1 and 2, to get how today's people live their World War 3 (which was planned to last many decades to come while it hits one region after another, every 10 years indecision).
By the way, I pay now for ATmega8L (100 pcs) what is equivalent to 1$ for each, and 3$ for 1000 resistors 1/2W 5%.
The luxury of buying and selling via mail (via local transport) is now a thing of the past... till new decisions will be made to allow us return to normal life smiley
Is Crickelwood Electronics still operating? I used them when I lived closer to the UK.
Ross McKenzie, Melbourne Australia
Yes.
Sorry for the delay. I attached here a few files concerning the new technique in generating periodic signals (now sinewaves only) that I mentioned and discussed on the previous posts. As you will see, its idea is based on using the MCU SPI function (MOSI pin only). So one passive RC filter (3rd degree) is enough to act as a low-pass filter for the high and low frequencies; 17544 Hz and  658 Hz.
The files are:
[1] SPIwaveGenerator.pdf , a Kicad schematic of the test circuit.
[2] SPI_bit_stream.zip , LTspice schematic that emulates the SPI output in the two cases.
[3] SPI_bit_stream.png , screenshot of LTspice emulation.
[4] SPIsine_2freq.hex , machine code (fuse settings included) for ATmega8L , to those who like testing it in real.
The main advantage of this technique is its simple hardware and its low cost as well.
But the creation of the data tables (one for each frequency that an application may require) is not a work for novice; mainly the tables that synthesizes the signals with minimum distortion (THD).
Sounds like something Don Lancaster wrote about many moons ago......
See posts #20 and #22
Great minds remember alike!
Sorry, I didn't know that Don Lancaster also thought of using the MCU SPI function.
On the other hand, I guess, from your comment, he also knew how to find out the data table for the actual SPI protocol although it hasn't a free running mode. After all, it wasn't made for such application in the first place.
I mean; you remind me two friends who went to watch a movie. When the great Lion of the Metro-Goldwyn-Mayer showed up on the screen, one of them said: "Oh, let us go out. We already saw this movie." cheeky
Speaking seriously, do you really believe that you can generate easily other frequencies (with low THD) just by reading Don Lancaster book.
Kerim
You need to apply what you learn from reading the book!
Kerim, you promote your technique as novel, but I'm not yet seeing the novelty of it. That's not to undermine your work, but there is a lot of prior art using similar techniques. As for using the spi peripheral, how is that different to outputting bits via a timer or i2S?
The main thing here is raw speed.
My concern is that I would not count on that push and pull of an IO is symmetrically.
From my past:
On a DSP I have used SPI for fast RS232 where each bit was 3 or 4 bits's long (this was before all the fractional UART's came out)
Add : it was only for TX
Sorry all, I am afraid that as long someone doesn't have time to try applying this technique in real, I can't take seriously his comments (and he will know why I am saying this now... from the first day he will decide to implement it as I did).
Kartman, so you think that with this simple hardware (nothing else), one can easily generate (or you may have done it already) sinewave signals in a rather wide spectrum (F_hi/F_lo equals about 30). Actually, by just inserting 3 more capacitors (using 3 NPN transistors), the spectrum could be extended to cover 20 Hz to 20 KHz.
+1
I've used SPI to create the timing for those WS2812 "neopixel" LEDs
(not an original idea).
By the way, when someone will find (using Google for example) an equivalent digital sinewave generator with the same simplicity (hardware) and cost (if not better, of course), the SPI technique, I presented to you, will be no more a novel idea indecision
That's not to undermine any one's work.
I simply had to think of and apply it because I needed such versatile digital generator (for my products) while I am not allowed to use any of the already known solutions due to... And, as you know, necessity is the mother of invention. I also liked it because it costs me less, besides its simplicity. But, truth be said, creating just the tables for 50 frequencies took me many weeks. Fortunately, the frequencies of the lower band (in the audio spectrum) can use these tables too.
It's still not 100% clear to me: is this a test "box" that only do this, or is it a part of a product that in "test mode" can make the tones ?
and how fast does it need to be able to change between different freq. ?
I have not seen your code but I expect that you make a delta modulator at max spi 4MHz or ?
Do you place the tables in flash or do you have a formula that can build the table(s), so it's placed in RAM ?
Do you do this in C or ASM ?
sparrow2 wrote:
It's still not 100% clear to me...
The clever bit of this project is that it uses a very simple RC filter to cover a wide range of frequencies, something that is normally difficult to do unless you start with a very high sample rate many decades above your highest frequency.
It's one of those neat tricks that come along from time to time. If you read the stuff I mentioned about Don Lancaster you'll get a bit of the background.
I like this kind of stuff.
but for me do we have 100% of CPU time for this, or less (same for flash and RAM).
In this case I don't care about the filter (for now), what I want to know if I(OP) can do whatever as long it's a 8MHz mega8 or only have 50% or something like that.
Is this for a sweep or one tone at the time or 2 tones for a modem  or ?
In my actual application, it is a part of a product. It has to produce, if not halted, a continuous bit stream that generates a sinewave signal at a certain frequency (actually, in the audio spectrum). For the time being, there are 100 frequencies only (using 50 tables).
In my application, the frequency index (from 0 to 99) is sent via TWI. So when the bit stream is interrupted by TWI (as a slave) and TWDR is read (the frequency index), the starting address of the requested table and its length are read, in turn, from the general index table before re-entering the SPI loop.
Manually, 7 pins could specify the frequency index. When the state of a pin (or more) is changed, the SPI loop stops and the new frequency index could be read from the state of 7 pins.
Yes, the table data are based on Delta Modulation. I chose the SPI Prescaler of fosc/4. So the frequency of the SPI clock is 2MHz.
I wished there is a formula; this would have saved a lot of work. So the tables are placed in flash.
I write always my code in assembly. So I am not sure if, by using a C compiler, the exact timing could be achieved.
By the way, since the time of ZX Spectrum microcomputer, I was familiar with delta modulation for saving/playing speech signals (300 Hz up to 3.3 KHz) digitally. One of the project, as a hobby, was scrambling the voice (on phone) by reversing the bits every 100ms (if I remember well). But, by using the ICs that I was able to get at that time, its board had to be rather too big (not practical).
Now, the existing SPI protocol has a surprise to those who will try to use its output (MOSI) as if it were the output of a delta modulator. The surprise is that MOSI pin has a break/dead time (at a constant level) between every two consecutive transmissions. This timing is emulated on LTspice (#38) and could be seen if SPI_bit_stream.asc is simulated and the PLS1 or PLS2 is plotted and magnified.
sparrow2 wrote:
but for me do we have 100% of CPU time for this, or less (same for flash and RAM). In this case I don't care about the filter (for now), what I want to know if I(OP) can do whatever as long it's a 8MHz mega8 or only have 50% or something like that.
To me in the least, I needed a reliable simple low-cost generator to produce audio sinewave signals with practical amplitudes (say around 300 mV if buffered).
There is another ATmega8 to play the role of ‘brain’ :)
For the time being, only one sinewave at a time is of interest to me. But the code can let it be for a sweep.
On the other hand, I believe that this technique could be applied to generate any periodic signal (below 100 KHz) in case it is not available already by one or more ready-made generators.
By the way, the existing SPI protocol doesn’t have a free running mode (to eliminate the dead time after every byte transfer).
But this could be achieved by just adding a flag in SPSR and an 8-bit buffer register for SPDR in master mode (in this mode, MISO, SCK and SS could be used as I/O pins). So after transmitting the 8 bits of SPDR, the contents of its buffer will be loaded into it and the transmission goes on without interruption. It is up to the programmer to place, or not, new data in the SPDR buffer register before the end of the present transfer.
Edited:
But this could be achieved, by an MCU manufacturer, by just adding...
I ask because if you can make a R2R DAC and a DDS I would expect it to be better (there is one DDS here somewhere called Jespers DDS) that do that.
The tone is made in main, and is changed in a ISR, that make noise when freq are changed but that don't seems to matter in your case.
His code make an update every 9 clk (but with same quality can be done in 8 clk ) . so an update rate of 1MHz or 50 points for a 20 KHz sine wave.
This is an output bit rate of 8 megabit compared to your 2. (I know it's not 4 times better but I would into it)
Since you don't need same resolution it can be done down to 6 clk. so 4/3 MHz update.
For the SPI way, a easy way would be to look at each byte as a value between 0 and 8 and (or perhaps 2 bytes 0 to 16), and than make a DDS around that.
But first point I would make sure that there is no space between bytes.
Thank you, sparrow2, for your interesting hints. I will revise Jespers DDS carefully to find out if it is better in term of simplicity and cost in my case (covering from 20 Hz to 20 KHz).
By the way, I usually try avoiding R2R DAC because the best tolerance of the available resistors here is 5% (if genuine); not suitable for producing many sets having similar low THDs. But this may not be a problem when the actual crisis will be over and I can produce my boards in China again.
If you make the R2R out of 24 resistors from the same batch, the unbalance is very small.
add:
here is a link to Jespers code:
here is the "real" DDS part:
; main loop
;	r28,r29,r30 is the phase accumulator
;  	r24,r25,r26 is the adder value determining frequency
; 	add value to accumulator
;	load byte from current table in ROM
;	output byte to port
;	repeat
LOOP1:
		add		r28,r24			; 1
		adc		r29,r25			; 1
		adc		r30,r26			; 1
		lpm						; 3
		out		PORTB,r0		; 1
		rjmp	LOOP1			; 2 => 9 cycles
 And comments :
move table to RAM save one clk.
and because rjmp is two clk's one clk can be saved by having the code two times, just make sure there is the same time between the two out instructions.
so in your case 7 clk with a good resolution.
And from the numbers you have given you should be able to go down to 16 bit fraction, so that would be 6 clk.
I noticed now your add: , thank you.
By the way, I drew a schematic on LTspice to emulate DDS with 8-bit ladder. So now I can see the effects on the output THD when using real resistances having a certain tolerance for the R2R ladder. And it helps me adjust its output (as AC and DC) because I have to use, as a buffer, a low-cost opamp, as LM324/LM358, which is not rail-to-rail.
About R2R, I added a function which could be activated at boot to compensate, when necessary and to some degree, its non-linearity. This is done by using ADC to adjust the 256 entries of the ideal sine table. The new table is saved on the MCU EEPROM.
I guess the SPI technique is good only if applied by an MCU manufacturer as an added function (after giving it another name, I guess) since it uses just one pin. In this case, before enabling this function, the programmer needs just to set the first address (an internal memory space) and the data length that generates the required signal. The MCU will be free as before while it acts as a signal generator (though for relatively low frequencies). But perhaps, this was done already in a certain MCU family.
DMA controller?
re: gaps in the SPI output stream
Many years ago I needed to generate video on an AVR. And I needed real full CCIR spec compliant video. I also couldn't accept the gaps in the output that using SPI would cause.
So I used this technique...
OUT VideoPort, R1
LSR R1
NOP
NOP
OUT VideoPort, R1
LSR R1
NOP
NOP
...which gives a bit stream on Videoport bit 0 at Fcpu/4. Obviously this ties up a complete port, you just uses bit 0 as your output.
The 'clever' bit was to then put useful code in place of the NOPs and tracking flags across the video opcodes. IIRC BLD and BST came in handy there. By unrolling the loop for the length of the active part of a video line I was able to keep something like 60% of the CPU cycles available for other work.
