Friday Playtime
4 posts / 0 new
One of my new years resolutions was to 'play' more with various chips/boards/ideas so I decided to give Friday afternoons over to this. Earlier this week I found that, somehow, I'd manged to accumulate a total of 8, yes 8, ATmega4809 Curiosity Nanos.
So I bought a Curiosity Nano Adapter and mounted one on it, along with a FTDI chip breakout...
The 4809 Curiosity has an on-board nEDBG unit and so I was able to add an external tool into Codevision which uses atprogram to upload my .hex file to the 4809.
I've now accomplished the first two steps we should all take...a 1Hz blinky and an 115200 baud "Hello World".
how many of the problems posted here would have been avoided if people did that?
I'd say it's probably over 50%
frown
I always start with blinking an led! For one thing, it tells me if I have the clock running the speed I think I do.
Then I start adding functionality until I have the whole project working.
Without adult supervision.
As well as that, it tells you that you have got the tools working, the downloader working, at least some of the hardware working, the CPU running at the speed you expect, etc, etc ...
And having a LED that you know you can control is a great asset in testing & debugging going forward.
Similarly for the "Hello World".
These 2 things are key basic functionality before moving on to anything else.
EDIT
And a prime example of what happens when you don't do that:
#KeyBasicFunctionality
