which C standard(s) does Microchip's avr-gcc support?
3 posts / 0 new
I'd like to find out which C standards does Microchip's avr-gcc support. Looks like it goes up to C11. Is there a way other than trying different values for -std option?
user@Station:/opt/microchip/avr8-gnu-toolchain-linux_x86_64/bin$ ./avr-gcc --version
avr-gcc (AVR_8_bit_GNU_Toolchain_3.6.2_1759) 5.4.0
user@Station:/opt/microchip/avr8-gnu-toolchain-linux_x86_64/bin$ ./avr-gcc --help | grep standard
  -std=<standard>          Assume that the input sources are for <standard>
user@Station:/opt/microchip/avr8-gnu-toolchain-linux_x86_64/bin$ ./avr-gcc -std=c17
avr-gcc: error: unrecognized command line option '-std=c17'
user@Station:/opt/microchip/avr8-gnu-toolchain-linux_x86_64/bin$ ./avr-gcc -std=c99
avr-gcc: fatal error: no input files
user@Station:/opt/microchip/avr8-gnu-toolchain-linux_x86_64/bin$ ./avr-gcc -std=c11
The copy of the user manual that ships with it should show the standards it has support for.
EDIT: try:
C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\share\doc\gcc>Standards.html
and have a read through that. The copy on your hard drive should match the issued version of the compiler you have.
EDIT2: so....
PS so "14" is the latest.
(if you get a GCC 8 or 9 it would obvioulsy have later standards)
