the thing I would like to ask is as follows. Picking certain example for AVR-IoT (ATMEGA 4808 + ATWINC1500) one can notice that there is MQTT node on the flowchart. Which would indicate that Atmel Start (AS) can handle MQTT. On the other hand I cannot add MQTT functionality using AS (starting with fresh project). Is there a rationale for such situation? Is there an officially recommended procedure to implement MQTT libs?
