What is device ID 1E9702 for Atmega128 ?
7 posts / 0 new
Hello All,
I've bought 10 pcs Atmega128A AU 1902 (on label) chips.
After soldering and starting up one of them I found this ID:
Atmega128 datasheet page 253 tells me there is only one manufacturer listed with ID 1F.
What is the matter. Do I have some problems with these chips?
Ellen
Senior electrical engineer
You normally use the regular Signature bytes e.g 1E 97 02
Look at p289 in your datasheet.
The JTAG ID has a different value.   I am aware of JTAG ID but have never used it.
If you go further in the AS7.0 Programming Screen you will see "Device information"
I presume that JTAG Debug software might use the JTAG ID.   From memory,  most devices have a very different JTAG ID versus Device Signature.   It is confusing to see such "similar" values.
in the document you linked in #1
(oh just realised this is the page 289 David just referred to!)
EllenR wrote:
Atmega128A
So why are we in the XMega forum ? * Not any more. *
Screen Device information.
It's OK, the same signature ... & page 289 ! Thank You
I was intrigued.   So I read the Device Info for my ATmega128 board.
Device signature    0x1E9702
JTAG id    0xC970203F
Revision    M
I suspect that your device(s) are younger than mine.
I was surprised to see Revision F for date code 1902 when mine is Revision M for 0639 (year 2006, week 39 )
My device: Date of purchase 03/2019, firmware 1.29 actually updated.
Ellen
