Extruded Aluminum enclosure suggestions
10 posts / 0 new
Hey all,
I am going through the typical vendors as well as Aliexpress and I am having little success.
I am looking for an aluminum enclosure with internal PCB slots and mounting flanges.  I would like it to be anodized Black or Blue, but I am not sticking to those colors if I can find teh right sized enclosure.
My PCB is currently at 100mm x 65mm with max component height of 25mm.  The PCB has some wiggle room size wise so I am also not bound by the dimensions.
I only need 5 of them.
I would appreciate some suggestions.
East Side Jim
Jim,
This is the very reason that after approximating the size and placement aspects of the contents I then select the enclosure.
Ok, and I did follow your 'rule' as my board is 100mm x 65mm. I am looking around but not finding much to my spec with that size board, etc. hence asking for vendor suggestions others may have used in the past.
This doesn't look tooo far off, dimension-wise...the interior height might be a bit too low for your needs...they have a few other models on their website.
https://www.jameco.com/Jameco/Products/ProdDS/2292671Drawing.pdf
this is taller, but unfortunately much bigger, all around
https://www.jameco.com/Jameco/Products/ProdDS/2292679Drawing.pdf
this might fit the bill
https://www.polycase.com/ex-53
This is available in blue double anodize & looks like decent dimensions
https://www.amazon.com/B5-080BK-Anodized-Extruded-Electronic-Enclosure/dp/B07MZPRQ78?th=1
Very close, low, cost, tight height
https://www.adafruit.com/product/2229
Taller (30mm)
https://www.adafruit.com/product/2230
nice, but out of stock (someone else prob has)
https://www.walmart.com/ip/Unique-Bargains-113-x-70-x-35mm-Multi-purpose-Electronic-Extruded-Aluminum-Enclosure-Box-Golden/133371707
This has very perfect dimensions & low price...but gold color
https://www.aliexpress.com/item/32235776279.html?spm=a2g0o.productlist.0.0.1f276da9WKfZPi&algo_pvid=87093034-6a53-4e5d-85c7-44ceba9ae368&algo_expid=87093034-6a53-4e5d-85c7-44ceba9ae368-11&btsid=0914c515-0a62-4d6f-aaf1-dd55d6caa3f3&ws_ab_test=searchweb0_0,searchweb201602_4,searchweb201603_53
Here is the winner ....since it is the LAST one I will provide
https://www.aliexpress.com/item/4000101382770.html?spm=a2g0o.productlist.0.0.23aa22a7HewJ89&algo_pvid=af6b8fa0-4b92-4c33-83a5-86e2b978cb71&algo_expid=af6b8fa0-4b92-4c33-83a5-86e2b978cb71-2&btsid=bc6e489a-ec1d-402f-b578-d8cf114114f1&ws_ab_test=searchweb0_0,searchweb201602_4,searchweb201603_53
NOTE:--you can get it here (NOTE--without mounting tabs) from USA $27 total by Feb 18 for quantity 5  free ship , several other sizes selectable as well
https://www.ebay.com/itm/Black-Extruded-Aluminum-Enclosures-PCB-Instrument-Electronic-Project-Box-Case/174124641055?hash=item288aa32b1f:m:m1XLVNudQTkOPAZfgw1KArw
Candyman!!
You certainly did not disappoint.  I saw some of them you listed, but the last one looks to be what I want.  I am going to contact the vendor in the morning
Thanks!
JIm
If you want something a little more upmarket.....
http://www.takachi-enclosure.com
There's also Hammond which are a quality but more economical solution.
https://www.hammfg.com/electroni...
NOTE:--you can get it here (NOTE--without mounting tabs) from USA $27 TOTAL by Feb 18 for quantity 5  free ship , several other sizes selectable as well
Based on the prices upmarket is an accurate description surprise
Hammond is in the mix as well.
The 5 from Ebay is a great price but I need the mounting flange....
JIm
Of course you need that once you saw it !   I couldn't find any with flange in the USA
I just noted they might be painted rather than anodized (if that matters)...thought it seems like they are anodized, since the color is even in little cracks
An even lower ali price ($2.81)  ...with tabs
https://www.aliexpress.com/item/4000282113314.html?scm=1007.22893.149154.0&pvid=a57fbfd2-0dd4-42e4-8fd7-1b83e59934c5&onelink_page_from=ITEM_DETAIL&onelink_item_to=4000282113314&onelink_publisherid=711069832&onelink_memberseq=0&onelink_duration=1.150779&onelink_status=noneresult&onelink_item_from=4000282113314&onelink_subid=NULL&onelink_page_to=ITEM_DETAIL&aff_request_id=b8366f06549a40919ebc2cbb4d79f256-1581521731896-02480-IwPSPrK&aff_platform=promotion&cpt=1581521731896&sk=IwPSPrK&aff_trace_key=b8366f06549a40919ebc2cbb4d79f256-1581521731896-02480-IwPSPrK&terminal_id=1dee113e5af4491b89f1a37114324674
this one says anodized (or they lie)..if true, they probably all are
https://www.ebay.com/itm/100x76x35mm-Corrosion-Resistant-Aluminum-Split-Body-Aluminum-Box-Enclosure-/114028520910
sandblast/matte anodized finish
Heavy gauge extruded aluminum construction | Easier for drilling, soldering, screwing, problem fixing.
Excellent electromagnetic shielding performance;Front and back panels and fasteners are included.
Oh dear:
laugh laugh laugh laugh laugh laugh laugh
