what is __flash parameter
5 posts / 0 new
Hi
I have the following function declaration
void EthernetBuffer_add(const char c);
which gives this warning
!W C:\Workspace\Common\EthernetBuffer.h(5):[warning] Illegal storage class __flash for parameter 'c'. Storage class removed.
I am new to this stuff and really know what it measns
Can anybody clarify this for me ?
I think you'd better start by saying which C compiler you are using and where the code you are feeding to it originated.
"__flash" actually originated in the IAR compiler for AVR
Codevision has something similar but it is just "flash" (no underscores)
GCC used to have a thing called "PROGMEM"/pgm_read_XXX() but a "better" system was invented. To be compatible with IAR syntax the implementor chose to use "__flash" too.
I don't know if other compilers like Imagecraft ICC, Rowley, MikroC have some equivalent and whether it is "__flash" or something else.
In GCC __flash is only available in the C compiler, it is not supported in the C++ compiler. For the latter you can either use the older PROGMEM way of doing things or you can make a shared C/C++ project and put anything "__flash" into C not C++ files.
So it's kind of important to say which C compiler you use and where the code came from (as it may have been written for a different AVR C compiler).
Exactly.  I don't immediately recognize the format of that warning, either.
Perhaps true back when I was your age, but nowadays
The flash or __flash keywords can be used to specify that a constant must be placed in FLASH memory, no matter what is the state of the Store Global Constants in FLASH Memory option:
flash <type definition> <identifier> = constant expression;
__flash <type definition> <identifier> = constant expression;
At least pi will always be 3.1415926535...
