extern storage classes in c
22 posts / 0 new
I have been reading extern storage classes but I do not understand.  I wrote a program that has two files
File 1
#include <stdio.h>
int x = 0;
void foo();
int main() {
  foo();
  printf("%d", x);
  return 0;
File 2
extern int x;
void foo() {
  x++;
Can anyone explain how the external variable is used in c language?
Total votes: 2
Extern basically tells the compiler the variable or function is defined in another file. Your example of usage is correct.
sky33 wrote:
I do not understand
What don't you understand about it?
As  Kartman says, what you show is correct - as far as it goes.
It's hard to explain when we don't know what needs explaining!
One thing that's missing is to use a so-called "Header" file for the extern declaration, but that's an extra nicety - the code as shown is perfectly valid.
See: https://www.avrfreaks.net/commen...
This is standard 'C' stuff - so should be covered in standard C textbooks, tutorials, references, etc ...
http://c-faq.com/decl/decldef.html
Here are some 'C' learning & reference materials for you - including a free online 'C' textbook:
http://blog.antronics.co.uk/2011...
EDIT
sky33 wrote:
I have been reading
It may also be helpful to say what you've been reading - if it's on the interwebs, give a link so that we can see it in context.
And it's not just 'C'
Any programming language which supports modular programming has to have some means for a "module" to export things  - so that they are available for other modules to use - and a means for a module to import things from elsewhere.
In some other languages, you have to explicitly "export" things; or specify them as "public".
In 'C', everything at file-scope (unless specified 'static')  is implicitly Public; ie, can be "seen" by other modules - so 'C' has no keyword to identify stuff as Public.
EDIT
More on the use of 'static' here:  https://www.avrfreaks.net/forum/what-happening-code-if-i-am-using-static-keyword-front-function-code
I was not sure what i am doing is right, I thought I should show my work so Anyone can tell if there is a mistake in this
I have modified my code
#include<stdio.h>
#include"other.h"
void Func();
int main() {
 int x = 0;
  Func();
  printf("%d", x);
  return 0;
I have other.h file , What should i put in this file ?
extern int x;
void Func() {
  x++;
error: ld returned 1 exit status
Did you read the 'C' FAQ link I posted previously ?
http://c-faq.com/decl/decldef.html - it answers exactly this question!
And the forum link ...
I have read these links, as well as read other links. What is wrong with my header file, because of which I am not getting the correct output
So have you done what they tell you?
You haven't shown your header file - so it's impossible to tell!
As always, you need to:
  1. show your complete program- all the source files
  2. tell what you expected to happen
  3. tell what is actually happening
  4. tell what investigation / testing / debugging you have done to find the issue(s)
Please do not edit you post after someone has replied to it!
It makes nonsense of the replies, and makes the thread impossible to follow.
extern int x;
void Func() {
  x++;
If that is what's in your header, then you have not followed what the links told you.
There you have put the definition of the function in the header - do not do that!
That just tells you that the linker returned some error - there will be more detail of what, exactly, the error(s) was/were earlier in the build output ...
EDIT
EDIT 2
Also: https://www.avrfreaks.net/commen...
When I was editing post you replied,  that's reason I haven't seen your reply
Read, and follow, this...
Hmmm ... it looks suspicously like you revised the post in the light of my replies ...
Anyhow, the thing to do is to never make significant changes after posting.
If you want to make updates, then be sure to keep the original intact, and make the updates clear - eg, as I did in #10.
Anyhow, back to the point:
So you need to go back to those links; in particular, be sure to understand the difference between a definition and a declaration - as that is the key here!
Which is a bringing-together of this:  https://www.avrfreaks.net/forum/tut-modularizing-c-code-managing-large-projects
But note that Dean is a bit fuzzy on the distinction between declarations & definitions ...
I compiled your files and display using "avr-nm".  See below.
Note how in one object file 'x' is "B" or (bss) for zero-initialized data.  In the other object file 'x' is "U" for uninitialized.
The compiler makes the "U" designation based on your use of "extern" in the declaration.
The linker will resolve the defined 'x' in f1.o with the undefined 'x in f2.o.
mwette$ avr-nm f1.o
0000003e a __SP_H__
0000003d a __SP_L__
0000003f a __SREG__
         U __do_clear_bss
         U __do_copy_data
00000000 a __tmp_reg__
00000001 a __zero_reg__
         U foo
00000000 T main
         U printf
00000000 B x
mwette$ avr-nm f2.o
0000003e a __SP_H__
0000003d a __SP_L__
0000003f a __SREG__
00000000 T foo
         U x
The way I always remember this is that there is something IN a defINition but not a declaration. So declaration is where you just say to the compiler "there's going to be one of these created at some point but just for now all you really need to know about it to be able to handle it is either the data type (variable) or the input and output parameter types (functions)". The defINition is where you actually create the object.
With a special exception of "static inline" functions a .h file should never contain anything but declarations. You can tell a variable is a declaration not a definition because it always has "extern" on the front. While you can (optionally) do that for functions too you can usually tell a function declaration from a definition because one ends in a semicolon (eg "int add(int, int);") while the definition ends in a set of braces with (usually) some code in the middle.
I like that - I shall have to remember it!
smiley
The defINition is where you actually reate (sic) the object.
* "create"
Indeed: the defINition is the thing which actually causes resources to be consumed; ie, memory (whether data or code) assigned.
Isn't it always the case that you tell a function declaration (aka "prototype")  because it ends in a semicolon?
EDIT
clawson fixed the typo while I was typing!
If you want a minimalist example try this.
Create 3 files:
// my_module.c
// Source code file for your module
// Have it create a function & a variable to be used by other modules
// my_module.h
// Header file for your module
// This allows other modules to access your function & variable
// main.c
// This will contain you main() function
// Have your main() function access the variable & function exported by the other module
Now fill-in those files ...
BTW your mistake was to stop at TWO. Usually when things are shared from one module to another there are THREE files involved. A .c file that has the definition(s) of what is being shared, a .h file that publicizes / documents what the thing(s) is/are and another .c file that includes the .h and makes reference to the exposed item(s) to actually use them. So:
// shared.h - declarations...
extern int x;
void foo();
// foo.c - defINitions of "exposed" items
int x;
void foo() {
  x++;
// main.c - consumer/user of things provided by foo.c and documented in shared.h
#include <stdio.h>
#include "shared.h"
int main() {
  x = 37;
  printf("%d\n", x);
  foo();
  printf("%d\n", x);
  return 0;
Of course this is an UTTERLY TERRIBLE way to actually do this. No way should "x" be global and available for main() to "see" and change. It should belong privately to foo.c and the only access to it might be the foo() function to increment it and return the current value. If there is a need for main() to be able to set a starting value then make another function (bar() ?) that allows main() to ask for the value to be set.
There is little point in learning the mechanics of the C language if you don't understand how they are intended to be used.
"encapsulation": keeping data hidden from prying eyes so access to it can be controlled is a key concept in programming. Otherwise this code might have a "x = 123" anywhere across all the files that mysteriously changes the "x" that "belongs" to foo.
If you are just at the learning stage I would highly recommend you consider learning C++ not C as it is designed to make this kind of stuff "natural". What's more all that stuff in shared.h would all be grouped together in a "class" (like a struct) to more definitely show they are connected.
Ha! clawson has done that for you - in #19 !
Thanks to all of you to provide detail description.  I now understand use of the external storage classes
Jolly good - so please mark this as solved.
btw: Note that  'extern' is a storage class - not "classes".
This is not to be confused with Classes in C++ ...
EDIT
typos
