quick c++ question
31 posts / 0 new
Just a quick c++ question.  I have a c++ file, "test.cpp" with a function "void temp_test();" in it.  When I include the "test.h" file in main and try to call the "temp_test()" function I get the following error.
DEP ../../examples/getting_started_with_blue/main.c
CC ../../examples/getting_started_with_blue/main.c
LINK build/sama5d4-xplained/ddram/getting-started_with_blue.elf
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/main.o: In function `main':
D:\atmel-software-package-2.15\examples\getting_started_with_blue/../../examples/getting_started_with_blue/main.c:293: undefined reference to `temp_test'
collect2.exe: error: ld returned 1 exit status
make: *** [../../scripts/Makefile.rules:115: build/sama5d4-xplained/ddram/getting-started_with_blue.elf] Error 1
I've never used c++ before in an embedded environment and hope it is a silly error on my part.  Thanks lads!
found it lads,
#ifdef __cplusplus
    extern "C" {
#endif
extern void temp_test(int);
#ifdef __cplusplus
#endifs
Why is it main.c and not main.cpp if C++?
If you are mixing C and C++ then, because of name mangling, as you cross the C/C++ boundary you are going to need extern "C".
Hi Clawson,
I tried that but the software frame work assumes that main is a c file and not a cpp.
clawson, I have one last error.  It is definitely due to the make file.  The error is listed below.  If I can get this error I will have most of the c++ working.
DEP ../../examples/getting_started_with_blue/test.cpp
CC ../../examples/getting_started_with_blue/test.cpp
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o:(.rodata._ZTI5Shape[_ZTI5Shape]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o:(.rodata._ZTI9Rectangle[_ZTI9Rectangle]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o:(.rodata._ZTI8Triangle[_ZTI8Triangle]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
make: *** [../../scripts/Makefile.rules:116: build/sama5d4-xplained/ddram/getting-started_with_blue.elf] Error 1
The code that causes this error is also below:
#include "test.h"
#include "stdio.h"
using namespace std;
class Shape {
protected:
    int width, height;
public:
    Shape(int a = 0, int b = 0) {
        width = a;
        height = b;
    virtual int area() {
        printf("Parent class area\n");
        return 0;
class Rectangle : public Shape {
public:
    Rectangle(int a = 0, int b = 0) :Shape(a, b) { }
    int area() {
    	printf("Rectangle class area\n");
        return (width * height);
class Triangle : public Shape {
public:
    Triangle(int a = 0, int b = 0) :Shape(a, b) { }
    int area() {
    	printf("Triangle class area\n");
        return (width * height / 2);
// Main function for the program
void temp_test(void) {
    Shape* shape;
    Rectangle rec(10, 7);
    Triangle  tri(10, 5);
    // store the address of Rectangle
    shape = &rec;
    // call rectangle area.
    shape->area();
    // store the address of Triangle
    shape = &tri;
    // call triangle area.
    shape->area();
    while (1);
The error disappears when I remove the virtual specifier.  Why?
Surely the easiest thing for a C project is to rename "test.cpp" as "test.c"
The IDE will compile it as a C file.   Along with all the other C files in your project.
"test.h" can remain unchanged because you already have the C / C++ guard.
It is common for a C++ project to have a mixture of C++ and C files.
All the header files have the appropriate conditional guard for extern "C"
I am not aware of any C projects that have C++ files
Just to clarify, I'm trying to setup a makefile to compile c++/
The following makefile command worked correctly for the above error:
-fno-rtti
New error that I need help with!
#include "test.h"
#include "stdio.h"
double division(int a, int b) {
    if (b == 0) {
        throw "Division by zero condition!";
    return (a / b);
void temp_test() {
    int x = 50;
    int y = 0;
    double z = 0;
    try {
        z = division(x, y);
        //cout << z << endl;
    catch (const char* msg) {
        //cerr << msg << endl;
    while (1);
ERROR
AR build/sama5d4-xplained/ddram/libsdmmc.a
CC ../../target/common/bootstrap.c
LINK build/sama5d4-xplained/ddram/target/bootstrap.elf
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o: In function `division(int, int)':
test.cpp:(.text+0x24): undefined reference to `__cxa_allocate_exception'
test.cpp:(.text+0x40): undefined reference to `typeinfo for char const*'
test.cpp:(.text+0x44): undefined reference to `typeinfo for char const*'
test.cpp:(.text+0x48): undefined reference to `__cxa_throw'
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o: In function `temp_test':
test.cpp:(.text+0xc0): undefined reference to `__cxa_end_cleanup'
test.cpp:(.text+0xcc): undefined reference to `__cxa_begin_catch'
test.cpp:(.text+0xd8): undefined reference to `__cxa_end_catch'
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o:(.ARM.extab+0xc): undefined reference to `__gxx_personality_v0'
./build/sama5d4-xplained/ddram/examples/getting_started_with_blue/test.o:(.ARM.extab+0x28): undefined reference to `typeinfo for char const*'
make: *** [../../scripts/Makefile.rules:118: build/sama5d4-xplained/ddram/getting-started_with_blue.elf] Error 1
18:10:48 Build Finished (took 1m:8s.256ms)
And when you Google those (common!) errors what do you find? At a rough guess I'd say you aren't linking the C++ std lib.
Hi clawson, I have googled the errors and found a few tips for the makefile that did not work.
Found a fella that got past the error by including the following:
libgcc
what I've figured out is, if I link against libstc++.a and libsupc++.a
I can get the link errors to go away.libgcc
So where do I include these in the makefile.  I've attached the makefile.
EDITED, this is not going to work - I think, lol.
I've got operator overloading and virtual functions working.  I'm working on exceptions now.
Still working on this.  If the project compiles and links without error but fails in the making of the OBJECT *.bin is the error definitely in the makefile?????
'all' twice, did AS7 do that?
#         SAM Software Package License
# Copyright (c) 2015, Atmel Corporation
# All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# - Redistributions of source code must retain the above copyright notice,
# this list of conditions and the disclaimer below.
# Atmel's name may not be used to endorse or promote products derived from
# this software without specific prior written permission.
# DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR
# IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
# MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
# DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT,
# INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
# OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
# LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
# NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
# EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# default target
all::
include $(TOP)/scripts/Makefile.vars
BUILDDIR ?= ./build/$(TARGET)/$(VARIANT)
#		Rules
include $(TOP)/samba_applets/common/Makefile.inc
include $(TOP)/flash_loaders/applets/common/Makefile.inc
include $(TOP)/scripts/Makefile.config
include $(TOP)/arch/Makefile.inc
include $(TOP)/utils/Makefile.inc
include $(TOP)/target/Makefile.inc
include $(TOP)/drivers/Makefile.inc
include $(TOP)/lib/Makefile.inc
include $(TOP)/scripts/Makefile.freertos
vpath %.c $(TOP)
vpath %.cpp $(TOP)
vpath %.S $(TOP)
OBJS := $(addprefix $(BUILDDIR)/,$(gnu-cstartup-y) $(obj-y))
LIBS := $(addprefix $(BUILDDIR)/,$(lib-y))
-include $(OBJS:.o=.d)
.PHONY: all build clean size debug
all:: build
build: $(BUILDDIR)/$(BINNAME).elf \
	$(BUILDDIR)/$(BINNAME).symbols \
	$(BUILDDIR)/$(BINNAME).bin
ifeq ($(VARIANT),ddram)
CONFIG_BOOTSTRAP ?= y
ifeq ($(CONFIG_BOOTSTRAP),y)
$(BUILDDIR)/$(BINNAME).elf: $(BUILDDIR)/target/bootstrap.elf
$(BUILDDIR)/target/bootstrap.elf: $(BOOTSTRAP_OBJS) $(LIBS)
	@mkdir -p $(dir $@)
	$(ECHO) LINK $@
	$(Q)$(CC) $(LDFLAGS) $(CFLAGS_CPU) $(CFLAGS_DEFS) -T$(bootstrap-linker-script-y) -Wl,-Map,$(BUILDDIR)/bootstrap.map -o $@ $(BOOTSTRAP_OBJS) -Wl,--start-group $(LIBS) -Wl,--end-group
endif
endif
$(BUILDDIR):
	@mkdir -p $(BUILDDIR)
$(BUILDDIR)/%.d: %.cpp
	@mkdir -p $(dir $@)
	$(ECHO) DEP $<
	$(Q)$(CC) -fno-rtti -std=c++1z $(CFLAGS_CPU) $() $(CFLAGS_DEFS) -MM $< -MT $(basename $@).o -o $(basename $@).d
$(BUILDDIR)/%.o: %.cpp
	@mkdir -p $(dir $@)
	$(ECHO) CC $<
	$(Q)$(CC) -fno-rtti -std=c++1z $(CFLAGS_CPU) $() $(CFLAGS_DEFS) -c $< -o $@
	@mkdir -p $(dir $@)
	$(ECHO) DEP $<
	$(Q)$(CC) $(CFLAGS) $(CFLAGS_CPU) $(CFLAGS_INC) $(CFLAGS_DEFS) -MM $< -MT $(basename $@).o -o $(basename $@).d
	@mkdir -p $(dir $@)
	$(ECHO) CC $<
	$(Q)$(CC) $(CFLAGS) $(CFLAGS_CPU) $(CFLAGS_INC) $(CFLAGS_DEFS) -c $< -o $@
$(BUILDDIR)/%.d: %.S
	@mkdir -p $(dir $@)
	$(ECHO) DEP $<
	$(Q)$(CC) $(CFLAGS_ASM) $(CFLAGS_CPU) $(CFLAGS_INC) $(CFLAGS_DEFS) -MM $< -MT $(basename $@).o -o $(basename $@).d
$(BUILDDIR)/%.o: %.S
	@mkdir -p $(dir $@)
	$(ECHO) CC $<
	$(Q)$(CC) $(CFLAGS_ASM) $(CFLAGS_CPU) $(CFLAGS_INC) $(CFLAGS_DEFS) -c $< -o $@
$(BUILDDIR)/$(BINNAME).elf: $(OBJS) $(LIBS) $(gnu-debug-lib-y) $(gnu-linker-script-y)
	@cp $(gnu-debug-lib-y) $(BUILDDIR)/target/
	$(ECHO) LINK $@
	$(Q)$(CC) $(LDFLAGS) $(CFLAGS_CPU) $(CFLAGS_DEFS) -T$(gnu-linker-script-y) -Wl,-Map,$(BUILDDIR)/$(BINNAME).map -o $@ $(OBJS) -Wl,--start-group $(LIBS) -Wl,--end-group -Wl,--no-undefined
$(BUILDDIR)/$(BINNAME).symbols: $(BUILDDIR)/$(BINNAME).elf
	$(Q)$(NM) $< >$@
$(BUILDDIR)/$(BINNAME).bin: $(BUILDDIR)/$(BINNAME).elf
	$(ECHO) OBJCOPY $@
	$(Q)$(OBJCOPY) -O binary $< $@
clean:
	@rm -rf $(BUILDDIR) settings
	@rm -f $(BINNAME).eww $(BINNAME)_$(TARGET).ewp $(BINNAME)_$(TARGET).ewd $(BINNAME)_$(TARGET).ewt $(BINNAME)_$(TARGET).dep
	@$(SIZE) $(OBJECTS) $(BUILDDIR)/$(BINNAME).elf
debug: $(BUILDDIR)/$(BINNAME).elf
	$(Q)$(GDB) -cd $(BUILDDIR) -x "$(realpath $(gnu-debug-script-y))" -ex "reset" -readnow -se $(realpath $(BUILDDIR)/$(BINNAME).elf)
include $(TOP)/scripts/Makefile.iar
It is just text, I am to tired to look for the zipper.
my projects: https://github.com/epccs
Debugging is harder than programming - don’t write code you can’t debug! https://www.avrfreaks.net/forum/help-it-doesnt-work
That looks like the most interesting thing in the whole file - but we don't see the contents :-(
Yet again we find an ARM-related thread from this user. You forum veterans are addressing this. Am I missing something?
