AVR 8-Bit Microcontroller Books/Tutorials/Guides/How-To Links
6 posts / 0 new
m learning to program the Atmel 8-bit AVR microcontrollers by re-designing a robot I built previously with an Arduino clone using AVR-libC and an (possibly multiple) ATmega microcontroller.
Disappointingly, I haven't found too many books about programming Atmel microcontrollers that are aimed at beginners, and of the ones I have found, many had poor reviews on Amazon.
in the past this man made a great book:
https://www.smileymicros.com/
it sort of looks like he has put things online now.
edit:
I am not sure if Joe is still the man behind the website.
The page seems to be started from scratsh on January 20th....
best look for a book from "Joe Perdue" on AVR and see if it comes up with a second hand book or some left over supply.
It was a great book on learning C and working with an AVR.
because the actual programming is really not specific to the particular brand of microcontroller!
See: https://www.avrfreaks.net/commen...
Programming is about problem solving; analysing a problem, and designing a solution.
That's 98% independent of the particular target hardware.
The bits which are specific to the particular  microcontroller - registers & peripheral operation - will be found in the manufacturers documentation for that particular  microcontroller
This thread could be a bit "out of date" now as it's not maintained like it once was:
Newbie? Start Here
But there's a lot of good information there.
Although an AVR - or any other microcontroller - is not a great target for learning 'C'.
Better to learn the 'C' language on a PC or similar - away from all the added complications of a small microcontroller.
Then, once you're up to speed with  the 'C' language - move on to applying it on a small microcontroller.
Here's my collected links for 'C' learning & reference - including a free online 'C' textbook:
http://blog.antronics.co.uk/2011...
Hello, here are 3 nice AVR books :
* in English :
https://www.elektor.fr/make-avr-...
https://www.elektor.fr/c-program...
* in French :
https://www.amazon.fr/Programmat...
